Home > Maintenance & Modifications > Under side protection
Page 4 of 4 <1234
BigRuss
As you put guards on you'll find you here things more when your off road, but its just the guards doing their job Thumbs Up Russell
2011MY 110 XS USW Black
Post #195596 21st Dec 2012 11:26pm
quentin
Australia 2004 Defender 110 Td5 SW Alpine White
Where do you guys all go that you need to line the underside of your Land Rovers like a Tank ?
I usually steer round rocks rather than try to push them out of the way. That said I have bent three track rods. One from running over a dead wombat.
Underbody Protection is a big no-no here because the spinnefex builds up under them and catches fire.
Are you guys familiar with offset Track rods, ( from USA), you can hardly see mine in the pic - (tucked up behind the axle tube) no way Im going to bend that !!
Post #198893 4th Jan 2013 1:23pm
jst
custom90steve wrote:
It would then act as a giant skid plate to "slide" over any rocks or branches stumps ect.
true, but it will also act as a giant suction plate when you are in the mud/bog.
there are pros and cons to most underneath options. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #198910 4th Jan 2013 2:17pm
Glynparry25
Here in Cyprus we have the same spinifex type scrub along with other types of bush grass, and with a average highest temperature of over 10 Degrees C more than the Melbourne area I have never seen a fire due to build up- but then again, after a days driving we always check undersides of the vehicles (everyone should be checking for bumps/ leaks etc anyway).
As I mentioned above..... it isn't about those rocks etc you see, it is for the one that is hidden (Mud/ water/ scrub). All you have to do is hit the diff pan and that is the front diff out of action- including the time it takes to remove the prop and drive shafts leaving you with '1 wheel drive' for the rest of the trip- which could also result in either abandoning an expedition at an early stage, having to get spares sent out to location (can be V expensive) or spending 2 days to traverse terrain that should only take 2 hours.
After doing a recovery job for 6 months in Belize sometimes we were driving for hours into the jungle to recover Defenders with snapped steering rods and bashed diffs......... All could have been avoided by spending the same price on under body protection as duel for the recovery truck to get there Rolling Eyes
Ric wrote:
The QT guards look ace, however they do lower ground clearance so will prob hit things I would have missed without them on Confused
Qt diff guard is 5mm? thick..... that means you lose 5mm of clearance. If something is missing my diff pan by 5mm I would rather have the protection and take the odd scrape.
Glyn Dog Sheep
Post #199025 4th Jan 2013 8:30pm
Glyn Dog Sheep
I'd have to agree with that comment too. Thumbs Up They also add a flatter more "slider" effect area to the bottom of the diff than not having a guard at all. The diff with no protection would be more blunt so would tend to be smacked with more force. Also a new replacement for a damaged guard would cost a lot less than having to replace a damaged diff or axle. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #199033 4th Jan 2013 8:41pm
Laurie
In fifty years of offroad driving, including a great deal of serious competitive, I've never used underbody protection.
In that time I've bent two trackrods.
Replaced at very little cost.
Underbody protection seriously reduces ground clearance making you more likely to bottom out.
Post #199051 4th Jan 2013 9:08pm
Ric
Fuel cooler / transmission guard now fitted, with a huge thanks to Brendan "Leeds" @ 4x4 overland
Probably the most helpful and genuine supplier of products for sale I have ever met!
Brendan gave a Sunday afternoon up to help a customer (me Smile not many would do that.
And the entreq products are perfect.
Thanks
Brendan its only a car!
Post #201519 13th Jan 2013 7:22pm
leeds
Was good to meet you Ric.
Am glad you like our service and Entreq gear Thumbs Up
Brendan
Post #201812 14th Jan 2013 7:04pm
Page 4 of 4 <1234
