Home > Maintenance & Modifications > Under side protection |
quentin Member Since: 23 Jul 2012 Location: on tour Posts: 119 |
Where do you guys all go that you need to line the underside of your Land Rovers like a Tank ?
I usually steer round rocks rather than try to push them out of the way. That said I have bent three track rods. One from running over a dead wombat. Underbody Protection is a big no-no here because the spinnefex builds up under them and catches fire. Are you guys familiar with offset Track rods, ( from USA), you can hardly see mine in the pic - (tucked up behind the axle tube) no way Im going to bend that !! Click image to enlarge |
4th Jan 2013 1:23pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8044 |
true, but it will also act as a giant suction plate when you are in the mud/bog. there are pros and cons to most underneath options. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
4th Jan 2013 2:17pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Here in Cyprus we have the same spinifex type scrub along with other types of bush grass, and with a average highest temperature of over 10 Degrees C more than the Melbourne area I have never seen a fire due to build up- but then again, after a days driving we always check undersides of the vehicles (everyone should be checking for bumps/ leaks etc anyway). As I mentioned above..... it isn't about those rocks etc you see, it is for the one that is hidden (Mud/ water/ scrub). All you have to do is hit the diff pan and that is the front diff out of action- including the time it takes to remove the prop and drive shafts leaving you with '1 wheel drive' for the rest of the trip- which could also result in either abandoning an expedition at an early stage, having to get spares sent out to location (can be V expensive) or spending 2 days to traverse terrain that should only take 2 hours. After doing a recovery job for 6 months in Belize sometimes we were driving for hours into the jungle to recover Defenders with snapped steering rods and bashed diffs......... All could have been avoided by spending the same price on under body protection as duel for the recovery truck to get there
Qt diff guard is 5mm? thick..... that means you lose 5mm of clearance. If something is missing my diff pan by 5mm I would rather have the protection and take the odd scrape. Glyn |
4th Jan 2013 8:30pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20413 |
I'd have to agree with that comment too. They also add a flatter more "slider" effect area to the bottom of the diff than not having a guard at all. The diff with no protection would be more blunt so would tend to be smacked with more force. Also a new replacement for a damaged guard would cost a lot less than having to replace a damaged diff or axle. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
4th Jan 2013 8:41pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
In fifty years of offroad driving, including a great deal of serious competitive, I've never used underbody protection.
In that time I've bent two trackrods. Replaced at very little cost. Underbody protection seriously reduces ground clearance making you more likely to bottom out. |
4th Jan 2013 9:08pm |
Ric Member Since: 03 Nov 2012 Location: South Yorkshire Posts: 209 |
Fuel cooler / transmission guard now fitted, with a huge thanks to Brendan "Leeds" @ 4x4 overland
Probably the most helpful and genuine supplier of products for sale I have ever met! Brendan gave a Sunday afternoon up to help a customer (me not many would do that. And the entreq products are perfect. Thanks Brendan its only a car! |
13th Jan 2013 7:22pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Was good to meet you Ric.
Am glad you like our service and Entreq gear Brendan |
14th Jan 2013 7:04pm |
