Home > Expedition & Overland > Norway 2013... Are you going???
Page 7 of 7 <1234567
It's not clear from this document whether you have to fit snow tyres for travelling thru Sweden but the first para read ...
Winter tyres
If you are travelling to or through Sweden with a vehicle such as a passenger car or heavy truck, you need to make sure the tyres on your vehicle are right. During the winter, the following rules apply:
http://www.transportstyrelsen.se/winter-tyres
I can't see any exception for foreign registered vehicles ...
Post #219782 17th Mar 2013 10:03am
K9F
Morning Steve....
I don't think there are any exceptions....
If you are travelling to or through Sweden .......These requirements apply to both light and heavy vehicles, as well as for vehicles registered in Sweden and abroad.
Interestingly I spend quite a bit of time in France and in the UK the minimum tread depth is 1.6mm. In France the minimum tread depth appears to be the same as in Sweden 3mm. With a company car it can be very difficult getting tyre changes authorised when you still have more than 1.6mm remaining. You can still get done for it abroad if less than 3mm....
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #219786 17th Mar 2013 10:13am
a13x
Just thinking about a trip for early next year....
Post #353308 23rd Aug 2014 7:55pm
Depending on work I'll be going but I'm not sure if you have seen the post from Phoenix the ferry to Denmark finishes in sept 2014 so it's going to have to be the long way around
Post #353344 24th Aug 2014 5:28am
a13x
No not seen that. I had read early this year about a new ferry route being set up but not kept an interest to see if it followed through.
Post #353353 24th Aug 2014 9:02am
Cold_n_Wet
Norway
We have been waiting for the new ferry since 2008, so donīt hold your breath.
There is the trucker ferry from Imingham to Breivik or Goteborg but its not you regular ferry, its a boat that carries trucks and passengers...
DFDS Tor-lines.
Ther Superspeed from Hirsthals to Larvik or Kristiansand are OK, we played on the beach at Hirsthals before heading home in June.
take sand tracks if you go alone on the beach... Embarassed not telling why.... "Rafiki" 2007 110 STW - Rolling rebuild.
Post #353462 25th Aug 2014 1:11am
