Home > Maintenance & Modifications > Front grill project COMPLETED!!!! uffff........
Page 4 of 6 <123456>
mobilecentre
The Speaker lights clearly have the ECE approval marked on the lens
Post #171134 26th Sep 2012 9:03pm
dgardel
Italy
ericvv wrote:
Sounds good Daniele, finally a clear response Thumbs Up
Still looking forward to see pictures of the sidelights at dusk.
With light daylight
Dusk
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #171155 26th Sep 2012 9:57pm
dgardel
Italy
ericvv wrote:
Just home and took a look at the lenses of my clear SVX headlamps. I see a lot of numbers on the bottom, and in the middle in a circle E9. But I see nowhere any sign of the mentioned ECE R112.
How to understand that? Should the ECE R112 be visible somewhere on the glass, and if not, how to know that either my current original lights or those Speaker LEDs are ECE R112 homologated? I want to avoid any issues with our Swiss MOT equivalent.
Still unclear to me.
The "E9" mark means the European Country where was made the homologation.
E mark from the Economic Commission for Europe (Economic Commisssion of Europe, referred to as ECE) regulations promulgated by (Regulation). ECE, including the current 28 countries of Europe, with the exception of EU member countries, also including Eastern Europe, Southern Europe, Africa and Europe and other countries. ECE regulations apply to all members is recommended, not mandatory standards. Member States can be applied to ECE regulations, can also be extended using its own laws and regulations. At present, the demand from the market point of view, usually willing to accept members of ECE regulations in line with the ECE test reports and certificates. E signs the certificate of product components and system components is not the appropriate vehicle certification regulations. Access to E logo certified products, is accepted by the market. E common signs of domestic products are certified automotive light bulbs, glass, tires, triangular warning signs, automotive electronic products. E logo certification testing of the implementation of ECE member countries are generally technical services. E signs the certificate issuing bodies are members of ECE government departments. Countries the corresponding number of certificates:
E1-Germany;
E2-France;
E3-Italy;
E4-Netherlands;
E5-Sweden;
E6-Belgium;
E7-Hungary;
E8-Czech Republic;
E9 - Spain;
E10-Yugoslavia;
E11-British;
E12-Austria;
E13-Luxembourg;
E14-Switzerland;
E16-Norway;
E17-Finland;
E18-Denmark;
E19-Romania;
E20-Poland;
E21-Portugal;
E22-Russian;
E23-Greece;
E25-Croatia;
E26-Slovenia;
E27-Slovakia;
E28-Belarus;
E29-Estonia;
E31-Bosnia-Herzegovina;
E37-Turkey;
and, just for an example:
Returning to our JW Soeaker, they was homologated by E9 (Country: Spain) and they are marked ECE R112. Just like TIM said is the same homologation of the Original headlamps.
if you are installing the JWS 8700 is the same as you are installing an original Land rover headlamp NO WAY!
IID Pro MV License
Post #171163 26th Sep 2012 10:18pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Looks like your in my parking space, yours is at the other end Laughing
Post #171164 26th Sep 2012 10:20pm
dgardel
Italy
SGH wrote:
What diameter are the two smaller lamps ?
85 mm DIA Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #171165 26th Sep 2012 10:20pm
dgardel
Italy
I saw it on your gallery Thumbs Up Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #171166 26th Sep 2012 10:21pm
SGH
dgardel wrote:
85 mm DIA
Thank you.. Thumbs Up 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #171194 27th Sep 2012 7:18am
dgardel
Italy
mobilecentre wrote:
Nice looking lights by the way Thumbs Up Whistle
Thank you TIM. Thumbs Up Thumbs Up Thumbs Up
I'll send you same photos that you will use on your site if you want. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #171201 27th Sep 2012 8:35am
ericvv
Post #171219 27th Sep 2012 9:08am
ericvv
Post #171220 27th Sep 2012 9:09am
mobilecentre
Chrome with front position fitted into an SVX
Post #171246 27th Sep 2012 10:05am
mobilecentre
You can clearly see the E mark at the bottom of the lens Thumbs Up
Post #171247 27th Sep 2012 10:05am
ericvv
Post #171249 27th Sep 2012 10:06am
mobilecentre
Black with front position light
Post #171251 27th Sep 2012 10:26am
ericvv
Post #171255 27th Sep 2012 10:43am
