![]() | Home > Maintenance & Modifications > Front grill project COMPLETED!!!! uffff........ |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
The Speaker lights clearly have the ECE approval marked on the lens
With light daylight ![]() Click image to enlarge ![]() Click image to enlarge Dusk ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
The "E9" mark means the European Country where was made the homologation. E mark from the Economic Commission for Europe (Economic Commisssion of Europe, referred to as ECE) regulations promulgated by (Regulation). ECE, including the current 28 countries of Europe, with the exception of EU member countries, also including Eastern Europe, Southern Europe, Africa and Europe and other countries. ECE regulations apply to all members is recommended, not mandatory standards. Member States can be applied to ECE regulations, can also be extended using its own laws and regulations. At present, the demand from the market point of view, usually willing to accept members of ECE regulations in line with the ECE test reports and certificates. E signs the certificate of product components and system components is not the appropriate vehicle certification regulations. Access to E logo certified products, is accepted by the market. E common signs of domestic products are certified automotive light bulbs, glass, tires, triangular warning signs, automotive electronic products. E logo certification testing of the implementation of ECE member countries are generally technical services. E signs the certificate issuing bodies are members of ECE government departments. Countries the corresponding number of certificates: E1-Germany; E2-France; E3-Italy; E4-Netherlands; E5-Sweden; E6-Belgium; E7-Hungary; E8-Czech Republic; E9 - Spain; E10-Yugoslavia; E11-British; E12-Austria; E13-Luxembourg; E14-Switzerland; E16-Norway; E17-Finland; E18-Denmark; E19-Romania; E20-Poland; E21-Portugal; E22-Russian; E23-Greece; E25-Croatia; E26-Slovenia; E27-Slovakia; E28-Belarus; E29-Estonia; E31-Bosnia-Herzegovina; E37-Turkey; and, just for an example: ![]() Click image to enlarge Returning to our JW Soeaker, they was homologated by E9 (Country: Spain) and they are marked ECE R112. Just like TIM said is the same homologation of the Original headlamps. if you are installing the JWS 8700 is the same as you are installing an original Land rover headlamp NO WAY! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
Looks like your in my parking space, yours is at the other end
![]() ![]() Click image to enlarge |
85 mm DIA Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
I saw it on your gallery ![]() ![]() ![]() ![]() IID Pro MV License |
Thank you TIM. ![]() ![]() ![]() I'll send you same photos that you will use on your site if you want. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Daniele, thanks for pics and all explanation.
![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Tim, please check your PM..... You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Chrome with front position fitted into an SVX
You can clearly see the E mark at the bottom of the lens
Tks Tim, do you have a similar picture of the black surround? You never actually own a Defender. You merely look after it for the next generation.
![]() Click image to enlarge Black with front position light |
Chrome it will be
