Home > In Car Electronics > The definitive Defender ICE thread |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20561 |
Well done that man. She'll be annoying you now mentioning how it reduces the size of the rear and how impractical it is. Just stick a massive Sub and Amp in there now. KEEP CALM AND Drill ON 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
27th Jan 2013 5:04pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 |
Maybe Just depends on how much she moans To be fair I don't think I've lost that much space. On another note, I had to give my sister a lift today, and she commented on how quiet the landrover is. She has been in it plenty, but not since I did the Dynamat ! Another big thumbs up for that - come on get yours done.
Just so she didn't feel lost, I cranked the stereo up |
27th Jan 2013 5:11pm |
It's only because it cuts down on the talking time.. So when you've had enough you can just turn on and crank up the sound system. KEEP CALM AND Drill ON
27th Jan 2013 5:14pm |
Think you mean listening Time or not listening as I regulary get told
27th Jan 2013 5:16pm |
Not so sure about that if you have a powerful enough Sub put in her hair would be the talking point instead. You know when the pressure hits.. (I'm sure you know what I mean) if not youtube search "subwoofer hair trick"
27th Jan 2013 5:25pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6771 |
Doesn't around 32/33 hertz do a lot more than mess with hair
27th Jan 2013 5:49pm |
Yes it does. KEEP CALM AND Drill ON
27th Jan 2013 6:06pm |
This arrived today:
Click image to enlarge Click image to enlarge Only bought really because the price was so reasonable. Currently raw Alu at the moment but with a coat of paint should look pretty good. Not sure if I'm going to use it though because I like my current one a lot. Might just keep for decoration. KEEP CALM AND Drill ON 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
28th Jan 2013 3:41pm |
Been pricing stuff up Problem with a sub is really I need a new head unit with 3 pre outs so I can have full control over the sound. Alpine are a bit short on the DAB front as yet, and the ones they do make are a bit over complicated futuristic (IMHO). Rough estimate to improve over what I have now will be £1000 inc a new head. Having played around with the set up, think I can live with it until they bring out a few more. I know it won't improve that much and the money can be better spent elsewhere. However I am in touch with my feminine side so I could change my mind at any point !
31st Jan 2013 5:32pm |
Kenwood Mine has the Pre out RCA's but I'm only currently using the sub ones as of now. And I know what you mean by control mine has all that. Where you can adjust settings individually. KEEP CALM AND Drill ON 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
31st Jan 2013 5:44pm |
Just want a simple looking (old skool) head unit like wot I got. Things start to get complicated when you run multiple amps, and you need to be able to change the settings as you change the artist recordings. Its a bit of a faph when you start altering the gains etc. Have you seen the new Rockford fosgate amp- 300 RMS 4 channel, about the size of 3 fag packets ???
31st Jan 2013 5:51pm |
Can't say I have but I know what you mean about the settings. A lot of different makes are going for small compact amps now. Just as good with the same output and often class D. Prices is the only thing though often a bit more but for the class D efficiency I think it's worth it. The Kenwood KAC - 1XD I think it's called is worth a look. KEEP CALM AND Drill ON
31st Jan 2013 6:01pm |
I also need to upgrade my tweeters which I'll be doing soon too. KEEP CALM AND Drill ON
31st Jan 2013 7:18pm |
Kicker tweeters are still in the pipeline and it's only a matter of time now. Certainly not cheap that's for sure at £90 a pair. KEEP CALM AND Drill ON
18th Feb 2013 11:46am |
