Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
kenl Member Since: 11 Jul 2022 Location: bunvegas Posts: 27 |
I wasn't even aware of it until Marc brought it up on here, it reminds me a bit of early Land Rovers that had a hand throttle that could be set. I don't know if it was standard or an add on? Anyways I used them a few times on very rough roads where it was impossible to keep any kind of steady pressure on the accelerator pedal.
Great thing!! |
14th May 2023 2:12pm |
jlrogers Member Since: 03 Jan 2013 Location: Houston Posts: 1 |
Anyone played around with turning off Engine Noise Cancel? My Defender arrives in a couple of weeks and hoping to start upgrading the sound system. Hoping to be able to turn off the Engine Noice Cancel and/or Active Noise Cancel (can't find any reference to ANC in CCF files)
MultiCAN-683 EngineNoiseCancel Not Supported |
14th May 2023 2:47pm |
marcd3301 Member Since: 11 May 2023 Location: Telford Posts: 22 |
Really pleased to have been of help. As you say over rough terrain where a steady pressure on the accelerator is needed, ATPC is a really useful tool. On a side note, when I checked with Patrick about inclusion in the beta he confirmed that the beta phase is over if buying new tools as its all part of the update when you are registering/activating. Cheers Marc -------------------- 20MY Defender 110 D240 First Edition, Gondwana Stone (enhanced with as much black as possible). Devon 4x4 winch mount, Bravo Snorkel fitted. 24MY Defender 110 D300 XS, Santorini Black. |
14th May 2023 4:44pm |
Hi Ian, did you ever manage to get your red dials? I seem to be in the same situation, all functionality is there, but the snazzy red dials just won't appear. Cheers Marc -------------------- 20MY Defender 110 D240 First Edition, Gondwana Stone (enhanced with as much black as possible). Devon 4x4 winch mount, Bravo Snorkel fitted. 24MY Defender 110 D300 XS, Santorini Black. |
15th May 2023 5:28pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1415 |
Hi Marc, unfortunately not I am still without red dials, hopefully the GAP team will work it out eventually Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
15th May 2023 8:17pm |
Click image to enlarge [quote=" Really pleased to have been of help. As you say over rough terrain where a steady pressure on the accelerator is needed, ATPC is a really useful tool. [/quote] I have had to remove ATPC from my CCF it would work but it caused a braking fault that stopped the cruise control amongst other things from work. The fault was quite difficult to clear as well. Click image to enlarge MY23.5 SE Defender |
16th May 2023 10:06pm |
MultiCAN-476 when you change it from HDC to HDC and LSPC can cause an emergency brake fault on some cars (mine included) To clear the error you have to change MultiCAN-476 back to HDC only and then lock the car up and leave it for 15-20 minutes, when you go back to the car reboot your pivi system by holding the on/off knob in until your pivi screen goes blank and re-boots. This should clear the fault Cheers Ian
16th May 2023 10:14pm |
Hi All,
I was again attempting to activate ACC when It struck me that the copies of various CCF that I have been using as a guide are woefully out of date given the way the IID has developed and increased visible features. To try and assist others, please find below a link to my most recent download of CCF config, which includes all aspects that make up the Off Road Capability Pack. Most of this was factory fitted, less APTC which has now been added by me: MultiCAN-476 ATPC Original: HDC Changed to : HDC and LSPC No warnings, no loss of other functionality. 15 min wait required, no Pivi reset. Please feel free to use the below config capture as necessary and I hope it helps: https://www.dropbox.com/s/k5kja04rbh9oe4t/...e.pdf?dl=0 If somebody who has factory fitted ACC, and has the most up to date IID software could return the favour with a recent config capture, it will be really appreciated. Cheers Marc. Cheers Marc -------------------- 20MY Defender 110 D240 First Edition, Gondwana Stone (enhanced with as much black as possible). Devon 4x4 winch mount, Bravo Snorkel fitted. 24MY Defender 110 D300 XS, Santorini Black. |
17th May 2023 9:23am |
I've just pm'd you a copy of my ccf file over, it's in 2 messages as the forum seems to have a limit on how big a message can be Cheers Ian
17th May 2023 10:36am |
You're a star thanks Ian.
Cheers Marc Cheers Marc -------------------- 20MY Defender 110 D240 First Edition, Gondwana Stone (enhanced with as much black as possible). Devon 4x4 winch mount, Bravo Snorkel fitted. 24MY Defender 110 D300 XS, Santorini Black. |
17th May 2023 10:43am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2769 |
l must get around to trying my GAP tool, it's been sat in the workshop for two weeks while l pluck up the courage to go through the 35 page setup process !!
17th May 2023 12:52pm |
It's nowhere near as complex as it first seems. A logical flow to register and activate, a little bit of backwards and forwards in the user guide but nothing too onerous. Take the leap, it's worth it.
17th May 2023 12:58pm |
As Marc says it's quite straightforward to use, once you have activated it with GAP give this a try. I posted a video a while back about how to change the startup screen to the James Bond one, a nice easy change, the video was shot in real time (apart from the 20 minutes wait time) so why don't you follow the video and try that. If you don't want the James Bond startup screen you can easily change it back by changing the setting again or you can restore the original ccf file to get you back to where you started. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
17th May 2023 1:15pm |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 163 |
I was thinking about the abs epb error, which often appears when editing ccf files, I've had this error in different situations:
when I changed the brake system type, from 18 inch to 20 inch. when i tried to configure acc when i tried to configure auto terrain response, or terrain response 2. the problem could perhaps be that the car automatically inserts epb when it is parked, perhaps for safety reasons the abs control unit is not coded. Has anyone tried the configurations, first bringing the abs and epb braking system into service mode? could be an idea, weekend I'll do a test |
17th May 2023 2:31pm |
