![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1434 ![]() ![]() ![]() |
If you look at my last post on the previous page you can see what can be done at the moment but you have to remember that the tool is still in the beta stage of development. That is why people are being unsuccessful with certain things at the moment. I'm sure Patrick or Steve mentioned that they will post a list on their website when the tool is in public release and say what can and can't be done.
![]() Apart from the ccf editing the IID tool is also a great code reader so you can figure out what is causing problems if you have any. That might not be attractive if your car is still in warranty and you can rely on your dealer/Land Rover rescue but it is a great tool to have in your kit. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Walk away locking & Approach unlocking are dependant on year, the consensus is that if you don't have the locking fuel cap these can be enabled.
Adaptive cruise & Advanced off-road capability pack are still a work in progress, I have factory ACC but am trying to get the Advanced off-road capability pack enabled but it's not working yet ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
kenl Member Since: 11 Jul 2022 Location: bunvegas Posts: 29 ![]() ![]() |
I have activated most of the items on the list, Except the DRL diming, the walkAway and Approach unlocking definately need the Pivipro reset, as does the 007 logo.
So far I don't have the dynamic mode working, I don't quite know where to look to switch it on once its been activated. More research required on that! I have turned on Gloabal close that is not available in Australia MultiCAN-723 SMRF global Close = Enabled It works as it should so I'm happy with that, had it on my D4 too. I have also tried to mess with the inacurate speedo, I don't know if my speedo is inacurate but suspect it is, the D4 was. I changed MultiCAN-838 from: Speedo market 0- 3.5% + 2kph To Speedo market 1- 2.0% + 0kph I will need to see if this works, I don't have, nor need a phone mount in this car so I don't have ready/legal access to the actual speed. Is there a hidden screen that show most Bus speed like the D4? Last edited by kenl on 11th May 2023 1:16pm. Edited 1 time in total |
marcd3301 Member Since: 11 May 2023 Location: Telford Posts: 22 ![]() ![]() |
I have today received GAP tool and am looking forward to getting to grips with it, and the wonderful world it opens up. I've read this thread from start to finish and thank all for the insights, but I have not identified anyone talking about ATPC (specifically ATPC not TR2).
Any tips from those more experienced? Cheers Marc -------------------- 20MY Defender 110 D240 First Edition, Gondwana Stone (enhanced with as much black as possible). Devon 4x4 winch mount, Bravo Snorkel fitted. 24MY Defender 110 D300 XS, Santorini Black. |
Edited: Apologies, double post. Cheers Marc
To answer my own post... MultiCAN-838 Speedo market 1 does work and makes the speedo acurate to +2%, at least according to Waze GPS speed.
Also of interest is that if you set the cruise control at say 110 on the speedometer the cruise set speed will say 114 and the actual speed will be 108, the 2%. I have not found how to adjust the cruise set speed to be the same accuarcy as the speedometer yet. |
Answered my own question. ATPC now activated, I forgot to wait 15 mins. No Pivi Reset required. Cheers Marc -------------------- 20MY Defender 110 D240 First Edition, Gondwana Stone (enhanced with as much black as possible). Devon 4x4 winch mount, Bravo Snorkel fitted. 24MY Defender 110 D300 XS, Santorini Black. |
In the spirit of this thread why not share your settings to help somebody else activate it
Apologies for not including in original post, you have a fair point.
![]() MultiCAN-476 ATPC Original: HDC Changed to : HDC and LSPC No warnings, no loss of other functionality. 15 min wait required, no Pivi reset. Cheers Marc -------------------- 20MY Defender 110 D240 First Edition, Gondwana Stone (enhanced with as much black as possible). Devon 4x4 winch mount, Bravo Snorkel fitted. 24MY Defender 110 D300 XS, Santorini Black. |
MattF Member Since: 28 Oct 2022 Location: Norwalk CT Posts: 32 ![]() ![]() |
When working you can select Dynamic as part of the terrain selections - interestingly on mine I can't use the knob to select Dynamic as I can with all the others. I have to actually press on the screen to get it to be selected. |
That's correct you can't select dynamic with the knob you have to touch the screen
tooth_dr Member Since: 26 May 2021 Location: Northern Ireland Posts: 237 ![]() ![]() |
Hi Marc. What is ATPC? |
All Terrain Progress Control, like an off-road cruise control
