![]() | Home > My Defender > 1988 Shire Blue Landrover 90 Restoration |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3480 ![]() ![]() ![]() |
![]() ![]() ![]() ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Looks great. I can understand your reticence at covering up such a shiny thing
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
As all hinge screws are going to be stainless, fabricated the nutplate that goes behind the middle hinge. The original, although still in good condition is for UNF bolts, but the stainless I have are metric.
![]() Click image to enlarge ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Almost a month since I could do anything on the 90. Managed to resum with the rear door.
The door was cracked and a cheap repair done early in its life in previous ownership. I never mounted the spare wheel for that reason, so as not to make it worse. To get it welded and repaired properly, the lower skin had to be taken off. Found quite some corrosion between the Ali and the steel, so now decided to de skin completely and have the frame galvanized. ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Lovely work, as always!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10874 ![]() ![]() |
Wow what a transformation from when i last read this thread, the detail is awesome and that colour combo is great, all that work you've done on the 90 is a credit to you
Thank you Clayton. Glad that you see quite some progress. Been working slow... so maybe you can see the transformation is because you were 'offline' for a while
![]() I hope I can finish the rear door some time soon, as then just the roof will remain (or so I hope). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Slow but sure is the way to go, taking each step / part as it comes
Got this picture from my nephew, as he took my rear door frame to get hot dip galvanizing while I am travelling. So excited to go back to see the results with my eyes 🤩
You haven't got time for travelling!!! Get on with the build!
You are absolutely right James
Haha, I note you don't say which Christmas!!
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3698 ![]() ![]() ![]() |
