Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 20 of 105 <123 ... 192021 ... 103104105>
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
tooth_dr wrote:
@hairy Dan
Cheers, I'll give that a go tomorrow Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #980578 30th Jan 2023 9:31pm
tooth_dr
Northern Ireland
I changed chirp on alarm to enabled and the emergency braking warning came up. I changed it back but the warning is still there. Is it likely to disappear itself???
Post #980673 31st Jan 2023 2:31pm
Hairy Dan
Have you tried to manually clear the fault, have you let the car go to sleep and rebooted the pivi screen? Cheers Ian
Kielder 4x4 Safari
Post #980675 31st Jan 2023 2:36pm
matt4x4
Germany
Yes - like Ian said - leave the car closed and alone for ~ 20-30 min
After that EAB should work again.
Had it every time after restoring after fiddeling with ACC
Post #980679 31st Jan 2023 2:49pm
tooth_dr
Northern Ireland
Thanks guys. I scanned for any faults and none were listed in the IID tool. I did PIVI reset too.
The car was closed and locked there for about 30 minutes, but the wife had to borrow the car and she phoned to say the lights still on for emergency brake assist. I'll not get a look at until after half nine tonight, but if it's still there I dunno Rolling Eyes
Post #980683 31st Jan 2023 2:53pm
Hairy Dan
If it's still there later on I would reflash your original ccf file and see if that clears it, I know I had a persistent brake fault when I was trying to activate TR2 and the only way to get rid of it was to go back to the beginning Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #980696 31st Jan 2023 4:49pm
tooth_dr
Northern Ireland
Cheers Dan. I'll try that if it doesnt reset.
Post #980698 31st Jan 2023 5:05pm
CLB87
Has any one attempted to activate the XM/Sirius tuner?
Post #980724 31st Jan 2023 7:17pm
tooth_dr
Northern Ireland
Did just that and it’s cleared. Cheers!
Post #980744 31st Jan 2023 10:03pm
tooth_dr
Northern Ireland
Exactly as you said, working now. Much appreciated
Post #980745 31st Jan 2023 10:04pm
IanR
Australia
Multican-814
Finally worked out how to edit, and upload CCF info - had to update my Android App (used on previous tools for D3 then D4) to the Beta version by activating on Play Store, to show the upload option.
Have just edited Multican-505 (walk away locking), Multican-566 (Remember stop/start).
Will check if changes have been applied later today.
Also edited Multican-814 (WiFiHotspot), with the account now showing on wifi connections on my android phone.
However, is asking for PASSWORD.
Any ideas on where to find?
Post #981182 3rd Feb 2023 11:27pm
forzahog
United States 2016 Defender 110 Other Works V8 Auto Fuji White
I believe you can set the password on the pivi screen under connections. I'm not by my defender right now or I would check. 20MY Defender 110 Fuji White
Post #981183 3rd Feb 2023 11:32pm
IanR
Australia
Thankyou. L663 Defender 90. D250 Mild Hybrid 23MY. Tasman Blue
Post #981184 3rd Feb 2023 11:35pm
IanR
Australia
Have just returned to vehicle. No change until I reset Pivi.
Now settings show the hotspot and password - connected my Android mobile without problems.
Also, option to set walkaway locking - which worked.
Will check 'Remember stop/start' setting is working next time I get to vehicle.
The Speedometer is way out: GPS at 70kph, Speedo shows 76kph.
I checked Multican-597 (TyreSizeCorrnFac) which correctly shows 255/70/18 (on OE steels)
Post #981187 4th Feb 2023 12:18am
tooth_dr
Northern Ireland
Anyone any further on with any other activations?
What is the purpose of the beta test? Is it to feedback to GAP? What’s the end result? Will GAP publish a list of known activations that work etc?
Post #981212 4th Feb 2023 10:24am
