![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1427 ![]() ![]() ![]() |
Cheers, I'll give that a go tomorrow ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
tooth_dr Member Since: 26 May 2021 Location: Northern Ireland Posts: 237 ![]() ![]() |
I changed chirp on alarm to enabled and the emergency braking warning came up. I changed it back but the warning is still there. Is it likely to disappear itself???
Have you tried to manually clear the fault, have you let the car go to sleep and rebooted the pivi screen? Cheers Ian
Thanks guys. I scanned for any faults and none were listed in the IID tool. I did PIVI reset too.
The car was closed and locked there for about 30 minutes, but the wife had to borrow the car and she phoned to say the lights still on for emergency brake assist. I'll not get a look at until after half nine tonight, but if it's still there I dunno ![]() |
If it's still there later on I would reflash your original ccf file and see if that clears it, I know I had a persistent brake fault when I was trying to activate TR2 and the only way to get rid of it was to go back to the beginning
Cheers Dan. I'll try that if it doesnt reset.
CLB87 Member Since: 17 Mar 2021 Location: USA Posts: 7 ![]() |
Has any one attempted to activate the XM/Sirius tuner?
Did just that and it’s cleared. Cheers! |
Exactly as you said, working now. Much appreciated |
IanR Member Since: 03 Feb 2023 Location: Gosford Posts: 3 ![]() ![]() |
Finally worked out how to edit, and upload CCF info - had to update my Android App (used on previous tools for D3 then D4) to the Beta version by activating on Play Store, to show the upload option.
Have just edited Multican-505 (walk away locking), Multican-566 (Remember stop/start). Will check if changes have been applied later today. Also edited Multican-814 (WiFiHotspot), with the account now showing on wifi connections on my android phone. However, is asking for PASSWORD. Any ideas on where to find? Last edited by IanR on 3rd Feb 2023 11:44pm. Edited 1 time in total |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 66 ![]() ![]() ![]() |
I believe you can set the password on the pivi screen under connections. I'm not by my defender right now or I would check. 20MY Defender 110 Fuji White
Thankyou. L663 Defender 90. D250 Mild Hybrid 23MY. Tasman Blue
Have just returned to vehicle. No change until I reset Pivi.
Now settings show the hotspot and password - connected my Android mobile without problems. Also, option to set walkaway locking - which worked. Will check 'Remember stop/start' setting is working next time I get to vehicle. The Speedometer is way out: GPS at 70kph, Speedo shows 76kph. I checked Multican-597 (TyreSizeCorrnFac) which correctly shows 255/70/18 (on OE steels) ![]() Click image to enlarge L663 Defender 90. D250 Mild Hybrid 23MY. Tasman Blue |
Anyone any further on with any other activations?
What is the purpose of the beta test? Is it to feedback to GAP? What’s the end result? Will GAP publish a list of known activations that work etc? |
