Home > My Defender > What Did You Do In Your Defender Today |
Mini Landie Member Since: 23 Sep 2015 Location: Basingstoke Massiff Posts: 159 |
Well I popped to my usual Landy specialist today to add the crossmember job to the list, and then on the way back my passenger wing mirror arm decides it doesn't want to hold tension anymore.
Not as bad as on a modern car to replace but still a pain in the arse. 2003 90 TD5 Hardtop |
16th Dec 2022 3:22pm |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 |
Last knockings on the shoot today👍
Click image to enlarge |
17th Dec 2022 6:25pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 859 |
Click image to enlarge Bank Holiday around the Brecon Beacons 2008 2.4 110 Utility Station Wagon XS. |
2nd Jan 2023 1:38pm |
KISSMYAURA Member Since: 13 Jan 2018 Location: KENT Posts: 45 |
fitted tacho and new dash lights
2nd Jan 2023 8:55pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
Crap photo waiting on the ferry to Mull on Christmas Eve, i had no internet for a week, it was bliss.
Sad fact, the large boat in the background belongs to the lighthouse board and is used to help maintain all the lights on the west coast of Scotland Click image to enlarge |
3rd Jan 2023 12:43am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
Brickbox - Great photo. Thinking of heading over there this coming summer maybe.
Yesterday, I wondered why my rear windscreen washer wasn’t working despite the fact I could hear it. I used the front washer jet and that was okay, but thought damn that must the something up with that rear washer jet. (Assuming the front washer jet was working > assumed fluid level was okay). I was thinking maybe the nozzles were blocked at the back or the pipe may have popped off the washer jet nozzle. Obviously, I checked the washer fluid level today and it was nearly empty. That was all it was, I was thrown by the fact the front washer jet was still working, presumably the front fluid pick up in the header tank is a little lower than the rear. Either way, I’m glad that’s all it was I’m surprised I had managed to use so much washer fluid since I checked it not that long ago, but with mucky roads and dirty road water spray it’s not surprising. Whilst I was there I did the usual checks, engine oil etc etc. So maybe worth checking your washer fluid and other items if you read this, might be a bit lower than you realise. And with the rain spell we have had it’s been easier said than done with checking these things. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
4th Jan 2023 8:28pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1364 |
Pulled it over the ramp with the intentions of giving it a service which i always do around Christmas/new year. Checked service book and i've only done 1100 mile in it this year so didn't bother. going to get some use out of it and service it in spring instead.
5th Jan 2023 7:51am |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 744 |
Clutch master cylinder is now kaputt! Why it didn't decide to die the same time as my transmission is anyone's guess. Upholding the old saying "Never over in a Rover" I reckon. In any case, new clutch master cylinder on order. Went with TRW as it was a "G" suffixed part and much cheaper than Girling!
I hope the parts arrive early next week so I can get on the road again. Luckily he decided to stop working in front of the house, but not in the garage so he's outside but at least not in the middle of the road. *SIGH* Last edited by HardCharger on 9th Jan 2023 5:41am. Edited 1 time in total |
6th Jan 2023 2:51am |
6th Jan 2023 7:40am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5877 |
Got the last two tyres swapped over today. Four nice new boots ready for the first forest stage rally in Feb. Now to sort out the worn BFG ATs ready for sale 1999 Defender TD5 110
6th Jan 2023 9:02pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17549 |
Yes, designed that way so that the rear squirter running out alerts you to the fact that the fluid is low but does so before the front squirters pack up. A piece of good design for once! I have my headlamp washer pump mounted where those of you with rear windows have your rear squirter, so that my headlamp squirters stop before my windscreen squirters. (My headlamp squirters are actually so awesome that they will effectively squirt the windscreen as well as the headlamps)! |
6th Jan 2023 9:35pm |
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 223 |
Took out the oven, fixed the diesel heater. Ordered lots of bolt on overlanding bits ready for our trip to Morocco in March.
11th Jan 2023 7:58pm |
Finally replaced the clutch master cylinder! A lot of removal of stuff before the cylinder itself then the fine tuning of the bite.
At least I'm back on the road again. I hope I didn't just jinx myself |
12th Jan 2023 6:28am |
Finally got around to fitting Momo Prototipo steering wheel, optimil quick release boss and Mudstuff seat rails, WOW!
14th Jan 2023 4:43pm |
