![]() | Home > My Defender > What Did You Do In Your Defender Today |
dannyragsdale Member Since: 06 Oct 2022 Location: Eastern Highlands, PNG Posts: 40 ![]() ![]() ![]() |
Finally got around to installing my Fox shocks all around. What a difference it made too!
![]() Click image to enlarge ![]() Click image to enlarge |
Mini Landie Member Since: 23 Sep 2015 Location: Basingstoke Massiff Posts: 159 ![]() ![]() ![]() |
It HAS made a difference! It gave you a 50" lift.
Yeah, it is an incredible place here. Been here almost a year and work in that small auto shop that is part of a NGO. If you've been here, you probably know the need for the high end shocks then. I've been a lot of places in the world and these are some of the roughest. The people are some of the best though.
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 577 ![]() ![]() ![]() |
Please elaborate on the difference. I'm considering changing the damper from factory but I'm suffering from indecision due to the wide choice available. |
I'm going from stock shocks with over 95,000 kilometers on them. It's like going from driving an old tractor to driving a Cadillac. There isn't a decent paved road for more than 30 kilometers away from where I live, so they're like floating on a cloud compared to what I have been using.
I am not sure what setting you will be driving your vehicle in, but I imagine Fox shocks being impressive no matter where you live or what type of roads you are driving. [/quote] |
Serviced the Optimill windscreen washer jet... https://www.defender2.net/forum/post978363.html#978363
Berni99 Member Since: 02 Jan 2022 Location: Bath Posts: 37 ![]() ![]() ![]() |
Wrote to my LR specialist to ask when it will be fixed!!!
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1855 ![]() ![]() ![]() |
Not today but Saturday afternoon whilst poottling down the M6 to an event Enfield way on the Sunday, massive hissing noise was suddenly experienced, quickly followed by the engine management light and a drop in power.
Limped to the next junction and discovered yet again the same problem ![]() Click image to enlarge The pipe has worn through again on the top of the steering knuckle. We pressed on (slowly) and get the event done, parts on order, so I can see what next weekends task will be 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Dave12345 Member Since: 04 Jun 2022 Location: North West Posts: 87 ![]() ![]() ![]() |
Pressed back into daily service after selling my Golf R - absolutely loving it.
Was told it’s a “sick truck” by some of my year 8 students yesterday. Discovered a McDonald’s coffee slots perfectly into the dash (but is far far harder to get back out again). |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 ![]() ![]() |
Stuck half a bale in the boot to top up the horse feeders as the fields are frozen solid.
Brilliant
I must admit it’s not bad, i wouldn’t have driven in otherwise too much to trash when it’s soft, i couldn’t even see tyre marks it was the frozen, didn’t even need to lock the diff to crawl up the hill either
Honestly I pray for cold mornings like this in winter with long hair collies ![]() ![]() |
MattH268 Member Since: 01 Dec 2021 Location: Moray Posts: 66 ![]() ![]() ![]() |
First day of no ice around and unlikely to freeze overnight so pressure washed the underside of my 110HCPU. Plenty of salt on the roads. Got a bit carried away and blasted off some loose paint off the x-member, so added to my list of jobs is to paint it. When I bought the vehicle it had cheap dynamic side repeaters fitted (not a fan) drivers side keeps falling off as the plastic had broken, I repaired it to wedge back in the wing but now the lens on the offside has fallen off so I've ordered new non dynamic led side repeaters.
![]() Click image to enlarge 300tdi 90 CSW 2.2tdci 110 HCPU 1972 Series 3 88" Truck Cab |
