Home > Modifications & Maintenance (L663) > BREMBO 6-Pot Brake Upgrade
Page 3 of 5 <12345>
mmbanf
Italy
Upgrade failed
Hi, I want to update for this upgrade on the brakes. unfortunately the system is not 100% compatible, and it is not a simple plug and play, as far as my 90 3.0 D200 car is concerned, with 349 mm front brakes and 320 mm rear brakes.
the new front discs are noticeably thicker on the hub bearing plate. this leads to less wheel engagement (as also highlighted by Vulkan auromotive).
the biggest problem remains that this thickness moves the disc outwards by 5 mm, in this way the caliper is no longer aligned with the brake disc.
for some, the solution could be to insert shims between the caliper support and the caliper itself.
I find this solution unsafe and problematic, the only solution is to replace the wheel hubs (all 4). I won't do this, I think I will sell all the material purchased.
in the photos you can see the original disc, the 380mm Brembo disc, the hub, the increase in distance from the caliper support.
Post #975998 29th Dec 2022 6:34pm
aajr
United States
mmbanf: Curious if you and thepetrolhead used the same kit, since he reported successfully installing the bigger brakes?
Post #976202 31st Dec 2022 6:26pm
mmbanf
Italy
hello,
the big brakes can also be installed without replacing the hubs, , but you need to insert engagement rings for the wheels, and spacers for the calipers.
I do not like this.
Post #976207 31st Dec 2022 7:03pm
aajr
United States
Sono d'accordo con te. Grazie.
Post #976334 2nd Jan 2023 4:48am
cl65amg
United Kingdom 2016 Defender 90 2.5 TD HT Auto Shire Blue
This post has been edited by the site administration team: commercial spam
Post #976632 4th Jan 2023 9:21am
OldDD
Isle Of Man 2012 Defender 90 Puma 2.2 HT Orkney Grey
That may well explain why the upgrade has been a simple bolt on for one member and not for another.
Either way spacers and longer bolts would make perfect sense on how to solve the issue when you look at the photos provided above
Post #976634 4th Jan 2023 9:25am
cl65amg
Yes, I had the same concern before buying the kit.
That's why the they asked me for the VIN number to see what spec I currently have before sending the complete kit out.
Post #976635 4th Jan 2023 9:30am
mmbanf
Italy
I studied the fittings of all the defender l663, I can say with certainty that on all versions with 18 (249 front, 225 rear) or 19 (265 front and 250 rear) brakes to install the 380 mm front and 365 rear discs with Brembo six-piston front caliper, ALWAYS insert shims between the supports and the brake caliper.
the question is very simple, the disc of the 18", 19" systems has a thickness on the plate in contact with the hub of 2.5 mm, the disc, the 20" system has a thickness on the plate of 8mm, this leads to a deviation of 5,5 mm, caliper-support, this will be the thickness of the spacer used by Vulkan.
another problem remains that the wheel bolts, when inserting the 380 mm disc, will have a useful tightening of 5.5 mm less, and I don't know if this will cause problems...
Post #976653 4th Jan 2023 11:54am
Retroanaconda
This is interesting. I think the smallest brakes are a little undersized for the vehicles weight, and get quite hot which causes the juddering fault that many have experienced.
I wouldn’t mind swapping for the middle size brakes - what you refer to as the 19 size. But I would not want to change my 18” steel wheels and I’m not sure if they would still fit?
I believe it’s only the biggest brakes (as fitted to D300/P400/V8 models) that don’t fit over the 18” wheels but I could be wrong.
Post #976686 4th Jan 2023 5:57pm
cl65amg
As far as I understand, the brake size is not determined by engine size but by trim levels or extra factory added options.
Only X models and V8 get the 6 pot as standard. Orange color on X model and Blue or black on V8.
For example, P400 XS is a 4 pot and P400 X has a 6 pot. All diesels get 4 pot even it is a HSE.
The only exception is if one chooses the factory optional 22' for £2.5k, then it will be a 6 pot in a non-painted color, not red, not orange, not blue, but the white greyish color.
Post #976706 4th Jan 2023 8:28pm
mmbanf
Italy
upgrade success wow
good morning to all the boys,
Today I finally successfully completed the 380mm disc brake upgrade with Brembo six piston calipers.
I decided to have the calipers painted by a professional with the original Land Rover Defender Brembo Blue specification. they are actually beautiful.
Second phase, I bought the two new 380mm original Brembo system front hubs/bearings.
Then I did a great job, removing the hubs was difficult, I used a joint extractor and with a lot of effort we replaced them.
Even bleeding was not easy, after the procedure that can only be done in service mode, (gap tool) you have to follow special rules, I had abs errors that didn't want to go away.....
Using the Gap tool, I modified the ccf file, relating to the diameter of the front discs, from 18' to 20'. Thumbs Up Thumbs Up
Post #983548 24th Feb 2023 2:31pm
mbso
Italy
Wow Thumbs Up what a work !!
Great Bow down
Bravissimo !! DISCOVERY 4 2013
VOLVO XC90 2017
MY23.5 110 D250 SE in Santorini Black
Post #983587 24th Feb 2023 9:14pm
Cedric74
Belgium
I’ve just painted mine.
Post #983892 27th Feb 2023 5:24pm
chrispuk
jackie wrote:
Thanks a lot for the prompt response.
Just a bit curious the difference between D250 S and D300 SE. The difference in $ is £6000. I only see the D250 is 50bhp down, smaller brake and a bit of interior difference. Why is the difference so huge in price?
Still deciding between the two and don't know if I shall spend £6000 more for D300 SE.
D250 plenty of power pulls, accelerates, & cruises well - same engine as D300 I believe but tweaked to get the extra 50hp
Post #992484 13th May 2023 2:59pm
mcma1
Got a little confused reading this thread.
So if you order the 22” on a D250, you get the same brake setup as the V8’s only not painted? Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1005689 29th Aug 2023 5:46am
Page 3 of 5 <12345>
