Home > General & Technical (L663) > 90 Commercial safety issue UPDATE THERE IS A SWITCH!! |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2926 |
l will pass that on, thank you for the information
30th Nov 2022 3:29pm |
Still waiting for a response from the dealer, and from Land Rover.
l had a call from Land Rover saying they would "look into it" Apparently the dealer is trying to find out if the harness/connector is still in place and Land Rover just deleted the switch. Last edited by lightning on 5th Dec 2022 9:34pm. Edited 2 times in total |
5th Dec 2022 4:03pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6120 |
More likely die of drowning! Same in my Td5 |
5th Dec 2022 6:43pm |
Land Rover and the dealer have both gone quiet regarding this tailgate release switch
l still think it's a serious safety concern. l sent an email to the salesperson who dealt with my vehicle last Friday, asking for an update, and (contrary to the normal response) have had no reply at all. l had one phone call from my LR customer service "case manager" at the end of November but nothing since. |
19th Dec 2022 9:20pm |
Looks like l am the only one who is concerned about this safety issue.
Dealer and LR still silent, no response to further emails. Anyone with a 2022/3 90 Commercial make sure the rear door can never close when you are in the load space because if it does, you won't get out unless someone opens the door from the outside. lt's okay on the flat but beware if you park facing downhill. Last edited by lightning on 29th Dec 2022 5:48pm. Edited 1 time in total |
29th Dec 2022 5:46pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1432 |
Raise it with HSE.
29th Dec 2022 5:47pm |
l may do, what if a child was to get trapped in the vehicle and they didn't have a phone with them. Or if you were in the middle of nowhere, the only way out would be to smash the rear window, if you had something heavy enough to do that.
What's the procedure for raising the issue with HSE? |
29th Dec 2022 5:50pm |
Uptoyouraxles Member Since: 16 Apr 2015 Location: Ayrshire Posts: 33 |
got my 90HT early November and I have a rear door release, took a while to find it but look on the LHS where the rear setbelt should have been.....
30th Dec 2022 11:36am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3689 |
It’s a bit off topic, but from your pics above, can the window panels be unscrewed and removed to reveal the window, or is there more to it?
Cheers Col |
30th Dec 2022 11:45am |
the panels come off but the glass has a thick film on the inside with fixings glued to it and there are some form of antenna also stuck to the glass.
So you could liberate some space but I guess the pastic protects the glass from impacts for any loose items in the cargo area..... |
30th Dec 2022 11:49am |
me, l'm an idiot
My only defence is that the dealer didn't know it was there either Click image to enlarge |
30th Dec 2022 12:33pm |
It's alright my dealer did not know it was there either and I only found it when exploring my rear area in more detail
30th Dec 2022 12:56pm |
Thank you for the heads up, the dealer and Land Rover had gone silent and my next step was going to be contacting HSE
30th Dec 2022 1:23pm |
Thanks. |
31st Dec 2022 7:58am |
