![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1394 ![]() ![]() ![]() |
It's a new app update which is sounds like you have if you updated on Tuesday
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 66 ![]() ![]() ![]() |
Patrick had to enable something ("full list"?) for my account and then they showed up for me. 20MY Defender 110 Fuji White
pllr Member Since: 22 Nov 2022 Location: PA Posts: 24 ![]() ![]() |
First, I love this board!
Second, how is everyone feeling about the Dynamic settings? Are they pretty reliably set and work correctly? These settings from @Matt4x4's summary posting: - Dynamic Mode EUCD-245 Dynamic-I Standard: Dynamic-i Not Fitted Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen MultiCAN-562 DynamicProgMode Standard: Not available for selection Changed to: Available for selection without timeout Other possible value: Available for selection with timeout MultiCAN-605 ConfigDynamicMode Standard: Not Fitted Changed to: Fitted |
I have those settings and it works as it should (I think) The only difference with mine is that my dials don't get the red accents, my cabin lighting is usually blue but when I change to Dynamic mode it it all goes red
![]() ![]() ![]() ![]() ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
zhihong.james Member Since: 14 Apr 2022 Location: Calgary Posts: 6 ![]() ![]() |
Regarding to programing the activity key, did you use the IIDTool BT or IIDTool Pro? From what I have been reading on the website, it seems only the more expensive IIDTool Pro version does the "Advanced Programming Functions" which includes the key programing. I am attempting to get my tool to do some tricks on my 2023 110x including adding a activity key to it. So I wonder which version of the tool I should get. It would be nice if I don't have to spend so much more on the pro version. |
umbertob Member Since: 21 Jun 2020 Location: Altadena, CA Posts: 133 ![]() ![]() |
I used the "regular" BT version of the tool to program the activity key, just followed the instructions of the routine and pushed the buttons on the touchscreen as if I was programming a regular fob. Took all of 30 seconds. 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround
Nice, it's time to pick up the IIDTool and find a activity key. Dealership told me they are currently out of stock and no ETA thanks for the chip shortage.
Ajay(UK) Member Since: 13 Feb 2021 Location: Arundel, W.Sussex Posts: 75 ![]() ![]() |
Hi Ian, I'm having the same problem but changing MultiCAN-745 back to not enabled doesn't solve the "EBA not available" message from showing up every time ![]() Andy. 22MY Defender 110 X Dynamic HSE D250, Gondwana Stone with too many options! Gone: 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. Gone: 2014 Discovery 4 HSE Luxury Firenze Red |
Does anyone else have an incorrect tire size in their CCF file? In our 2023 with 18-inch wheels, it's correctly listed at 18-inch wheels with the right dimensions.
Our 2022 has 20-inch wheels from the factory, but the CCF file says: MultiCAN-597 TyreSizeCorrnFac 255/65 R19 A/T TYRE I suppose it doesn't really matter since I would have never known but for the IIDTool, but I'm wondering if my recommended tire pressures are displaying correctly in the dash display. |
Mine is set to Not Supported. Have you tried rebooting the Pivi system? If it's still there after that I would suggest you drop Patrick a message ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
matt4x4 Member Since: 18 Nov 2022 Location: North Posts: 16 ![]() ![]() |
I tried the new acc settings with the different cruise settings already known
- not getting further, I still get the "EAB not avaiable" error. The gap config in the pivi is there but holds no changes. Also some of the new acc settings did not write to the car, they show the same values as befor my changes. I only played whis values which show up when searching after "acc" or after "cruise". After resetting it all to my standard values the EAB error stills shows up. I have to let the car sit locked for 20min or so. After that the the error disappears and everything works as before. I too did the new beta update on the tool and the app. The diff from the old config and "show unsupported" shows a lot of new values. A lot of things my car has, but their default value shows "unsupported" for example: EUCD-024 Rainsensor Not supported EUCD-031 Acknowl. Signal Lock/Alarm Not supported EUCD-032 Automatic Locking By Speed Not supported An I too have the "tyre" values showing the wrong tire size, but did not care about it, speedo and pressure values all work fine/are correct. |
I think that some of the values in the CCF list don't all apply to the new Defender, the CCF can cover a lot of vehicles so EUCD-024 Rainsensor - Not supported could be a rain sensor from a different model, so yes you have a rain sensor but not one that is controlled by EUCD-024. If you remember on EUCD-205 Racing Sub Brand that can be changed to the James Bond theme some of the other choices in there are Range Rover SVR, Jaguar and even Ford!
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 267 ![]() ![]() |
Simon from Powerful has just put a video out using the gap beta tool to add an activity key to his new defender 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
I have duplicated every setting from our 2022 Defender with factory ACC to our 2023 Defender without ACC, trying to get ACC to activate. I cannot get past the Emergency Braking warning.
Is there another step to reset or calibrate all of the sensors? In a link someone posted earlier, there is supposed to be a calibration procedure but I don't know how that would work if I can't get the cruise to activate with the EBA warning. (I also think @forzahog tried to do something like that already.) I hope someone can figure out the magic formula. |
