![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 67 ![]() ![]() ![]() |
PM me your full ccf list and I'll have a look. I made an earlier change that gave me that error. I may be able to spot it.
Kyle 20MY Defender 110 Fuji White |
umbertob Member Since: 21 Jun 2020 Location: Altadena, CA Posts: 133 ![]() ![]() |
I attempted something like that initially by "correcting" the size when I switched to 18" wheels (not sure if it was in the above entry or another one in the CCF, it may have been MultiCAN-596) and the speedo was thrown off big time after the upload, even though it appeared to me that I had selected a more appropriate tire size... It showed me going 120 mph when I was really coasting at 70... Everything went back to normal when I knocked that setting back to the original default, but I just wanted to give you a heads up. Tire pressure for all factory tires should be the same regardless of wheel size anyway (save perhaps for cars fitted with 22"), so as long as your speedo is accurate I would not mess around with those settings and leave them alone. 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1443 ![]() ![]() ![]() |
Personally I think there may be still one or two settings that aren't available yet that need to be set to enable ACC, just like how I can't get TR2 to work yet. The tool/software is still in its early stages of Beta and I'm sure the team at GAP are working to make all these settings available to us. The last update brought 5 new settings and I'm sure each update will bring more each time. Also if you do something and it brings an unexpected result/fault let Patrick know by submitting a bug report
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
MultiCAN-712 ACC Lead Car Distance Display is set as "Fitted" in my 2020 with factory ACC. The other two settings match your 2022's. 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround |
Just to confuse things
MultiCAN-712 ACC Lead Car Distance Display Not Fitted This is set to not fitted on my car and I have acc with queue assist from the factory Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
pllr Member Since: 22 Nov 2022 Location: PA Posts: 24 ![]() ![]() |
Thanks for that.
Hmm. I didn't change anything on the 2022 yet (mostly because I want the 2023 to behave the same way). Only downloaded the existing CCF file. So "MultiCAN-712 ACC Lead Car Distance Display" isn't respected by my car. Different subject, but I was hoping to turn on mirror dipping in reverse in the 2023, like I have in the 2022 (and most cars in the last 15 years). I changed the settings to match, but nothing happened. I suppose it needs the "memory" functionality/ECU to do that. |
zhihong.james Member Since: 14 Apr 2022 Location: Calgary Posts: 7 ![]() ![]() |
Will definitely have to check that out. But the main issue is cannot buy the activity key since they are out of stock now. |
Bob Heijnen Member Since: 29 Nov 2022 Location: Noordwijk Posts: 17 ![]() ![]() |
I receiver the IIDtool BT also and updated it. When connecting to my L663 it connects fine but the car config option does not show. Is there a setting I have to adjust? Help is appreciated.
Have you asked Patrick to join the beta programme? Cheers Ian
I did but not activated yet. Is it only accessible via beta?
Yes you need to use the Beta app to access the car config etc
Great, many thanks.
Cheers |
I have the beta app installed but still no car config option. Does the latest updates from the car prevent it? Any other tips?
Hi Bob have you tried opening Testflight and starting the app from in there
you should have version 4.1.0 (105) Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
