Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Bob Heijnen Member Since: 29 Nov 2022 Location: Noordwijk Posts: 17 |
Just wondering if the GAP tool is also usable for a Jaguar since the systems are the same. I own an IPace
29th Nov 2022 7:27pm |
PatGAPInnov Site Sponsor Member Since: 19 Jan 2015 Location: Montreal Posts: 45 |
Not yet but its in the plans http://www.gap-diagnostic.com/
29th Nov 2022 7:37pm |
pllr Member Since: 22 Nov 2022 Location: PA Posts: 24 |
I received the tool today and went through the activation process. For reference purposes in case it's helpful to anyone, here are the original (unchanged) CCF files from our two Defenders: a 2022.5 P400 SE (USA) and a 2023.5 P300 S (USA).
I'm hoping these links work. 2022.5 P400 SE https://www.dropbox.com/s/7mamv29jwwkxbuh/...A.txt?dl=0 2023.5 P300 S https://www.dropbox.com/s/udq8wyf6z6guk6j/...A.txt?dl=0 I looked at the differences between the files using BBEdit on a Mac. It's pretty interesting to see what's different between the cars. |
29th Nov 2022 10:24pm |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 66 |
Thank you, I'll start comparing with what I know so far and see if I can get anywhere on some of these other options. 20MY Defender 110 Fuji White
30th Nov 2022 1:54am |
Yeah, it's pretty strange. I have several settings that say I don't have something enabled, but I know for sure I have it. I think they're just not used. The ccf concept is a holdover from the Ford days and there are a lot that are just ignored.
Btw, can you go to your ccf list again and make sure to click "Unsupported" down at the bottom to list the full list? Then you can share the entire list where some values are hidden. Thanks for your help on this. 20MY Defender 110 Fuji White |
30th Nov 2022 2:11am |
matt4x4 Member Since: 18 Nov 2022 Location: North Posts: 16 |
A litte update ...
The driving lights can also be dimmed and not only turned off, an a foglight setting - Activate WIFI/WLAN Hotspot MultiCAN-814 IVIWiFiHotspot Standard: Not fitted Changed to: Internal WiFi Hotspot fitted - Change Splash Screen to "Defender 007" EUCD-205 Racing Sub Brand Standard: Mainstream Vehicle Changed to: LTD 007 - Dynamic Mode EUCD-245 Dynamic-I Standard: Dynamic-i Not Fitted Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen MultiCAN-562 DynamicProgMode Standard: Not available for selection Changed to: Available for selection without timeout Other possible value: Available for selection with timeout MultiCAN-605 ConfigDynamicMode Standard: Not Fitted Changed to: Fitted -Remember Stop/start setting MultiCAN-566 MHLastUserMode = Enabled -WalkAwayLocking MultiCAN-505 Change it to Current: Enabled Only available on MY2023 onward, if you don’t have a locking fuel cap you can enable walk away locking. You will also have to go into your centre screen setting and switch it on -Modify signature LEDs behavior MultiCAN-463 DRLBehWhilstDIsAct Current: Turn Off New: No Action Other possible value: Dim MultiCAN-465 DRLBehWhHazardsAct Current: Turn Off New: No Action Other possible value: Dim This setting is to keep them on while the turn signals or hazard lights are operating. Or only dim them. EUCD-018 Foglight Function Current: Depends on market Other possible values: Foglight without restrictions, Foglight not together with high beam |
30th Nov 2022 8:49am |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 429 |
Anyone figured out DRL with the rear lights on ?
So much more safe and good looking.. Thx. No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
30th Nov 2022 10:12am |
2022 P400SE with Unsupported Settings https://www.dropbox.com/s/mhh9i0174epi7r9/...d.txt?dl=0 2023 P300S with Unsupported Settings* (*I changed the Wifi Hotspot from stock) https://www.dropbox.com/s/1e0depjkbl7damj/...d.txt?dl=0 |
30th Nov 2022 12:50pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1418 |
Somebody pm'd me yesterday asking how to get all items on the list so I screen recorded this for them Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
30th Nov 2022 1:12pm |
umbertob Member Since: 21 Jun 2020 Location: Altadena, CA Posts: 133 |
FYI, although mine are set as "Fog light without restrictions", they still go out when the high beams are active. 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround |
30th Nov 2022 3:58pm |
Indeed, not all CCF settings are taken into account by the car. Its been this way since the beginning of the Ford era and passed down up to today. http://www.gap-diagnostic.com/
30th Nov 2022 7:23pm |
denhams Member Since: 21 Jul 2020 Location: Las Vegas Posts: 26 |
[quote="Hairy Dan"]
Does this work only for auto stop/start? If my last used mode was Eco, would it be Eco on the next start? 1981 Series III 88 Santana Especial 2020 Defender 110 SE 2023 Tesla Model 3 RWD |
30th Nov 2022 7:44pm |
Saving the TR mode was what I was hoping it would do too, but it only handles Start/Stop. 20MY Defender 110 Fuji White
30th Nov 2022 7:51pm |
