Home > Puma (Tdci) > Engine, Gearbox & Transfer Box Oil Change
Page 12 of 14 <123 ... 11 121314>
BrickBox
Bumping this thread - I may have missed a post.
But can anyone confirm that the gearbox, transfer case AND diffs all take the same oil?
Thank you Very Happy 2008 2.4 110 Utility Station Wagon XS.
Post #958110 13th Jul 2022 8:42am
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Yes. I used Millers Oils TRX 75W90 (5252). You'll need a lot of it if doing all gearboxes and axles.
Post #958124 13th Jul 2022 10:14am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
My Transfer box & Gearbox is spoilt with Millers CRX 75W-90 NT+ Fully Synthetic gear oil 😜.
The Diffs get cheap Dinosaur Juice changed annually.
Post #958132 13th Jul 2022 11:09am
X4SKP
Yes it can be the same oil... Thumbs Up
https://www.defender2.net/forum/topic84159.html SKIP
Post #958140 13th Jul 2022 12:08pm
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Is this the same for a 2014 2.2 puma? All oils the same? Gearbox, transfer box and both diffs?
Post #958852 19th Jul 2022 3:18pm
steveww
My Defender is 2.2 2015 so I think your 2.2 2014 should be the same.
Post #958955 20th Jul 2022 9:51am
pilsburypie
On another recommendation I went for GL4 for gearbox and GL5 for transfer and diffs. To be on the safe side. I’m sure the gearbox would be fine, but who knows. Been trouble free so far and want to keep it that way!!
Post #958961 20th Jul 2022 10:20am
Dirky4316
Tools recommended
Great comments thanks chaps. Bit of a basic request, As a new owner can anyone recommend what tools to have as a necessity and also recommend a pretty universal socket set?
Post #966350 1st Oct 2022 1:30am
Dinnu
Tools needed are actually on the 1st post of this thread.
However my gearbox plugs are Allen Keys (also called LN or hex) not torx. Cant remember the exact size but a guess would be 8mm. A set with a size range up to 10mm would be good to have.
Probably any decent set will do, tightening torque for drain plugs is not that high.
Edit: I should also add that also the fill plugs should not be over tightened. It is good practice to open the fill plug first before opening the drain plug. You do not want to drain the hole and then find that you cannot fill it up! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #966351 1st Oct 2022 3:04am
nitram17
This is a great thread and thanks to all who have contributed ..Does anybody have any tips/tricks equipment to reduce the mess when changing the oils? I only have a driveway to work on and if i spilt oil on he cobbles i would have to go into witness protection.
Does anybody use a funnel and hose to catch the oil from the engine ?
Post #966357 1st Oct 2022 8:32am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
I have never had an issue, large drain tank from Draper. The only time I stoped oil over the parking place was when it was draining from the drain pan/tank into a bottle to dispose of and I kicked it over.
https://www.drapertools.com/product/23258/...16l-black/ Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #966363 1st Oct 2022 10:02am
Be careful with funnels, it is very likely that the flow from the sump will overwhelm the funnel outlet (especially if there's a hose attached). You're usually better off with a drain pan with a large catchment area, but do be careful moving or emptying it when full.
Post #966369 1st Oct 2022 10:59am
Dirky4316
Thanks!
I was thinking more in general rather than the specific ones for oil change nuts
Post #966368 1st Oct 2022 10:59am
nitram17
Thumbs Up
Post #966373 1st Oct 2022 12:47pm
nitram17
thanks i will order one asap......
Post #966374 1st Oct 2022 12:51pm
