Home > Puma (Tdci) > Engine, Gearbox & Transfer Box Oil Change
Page 2 of 14 <123 ... 121314>
jayaway44
2012 Defender 110 Puma 2.2 USW Stornoway Grey
Great post, very useful. You state "The oil is Castrol Magnatec 5W-30 A1 Fully Synthetic Engine Oil (Recommended by Ford) " do you know if this would be the same oil for the 2.2l engine.
Thanks 2.2 2012 110 utility Orkney Grey
Also
Range Rover Evoque - Surprising but I like it.
Previous
Freelander 2 SD4 HSE - Black
90 TD5
Discovery 3
Early Discovery.
Post #155394 13th Jul 2012 1:14pm
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Hi,
I changed the oil in my Gearbox / Transfer / Diffs and put new grease in the UJ's today. Thought I would add some pics to aid anyone using this excellent thread which helped me. My 2009 110 has just spun around to 30K. I drained 2.2Litres out of the gearbox but only 2litres out of Transfer Box. Diffs were low to Rolling Eyes
The Oils used.
Fuchs 'Titan' for the Transfer box (2.4litres)
Castrol 'Syntrans' for the Gearbox (2.2Litres)
Castrol Axle 'EPX' for the Diffs (1.6Litres per Diff)
Transfer Drain plug -
Transfer Filler plug -
Diff Filler and Drain with oil -
Hope that helps Smile Cheers,
Superspoons
Post #155817 15th Jul 2012 11:18pm
taffyscouser
Anyone know the oil filter number for the 2.2 Puma. 2012
This is quoted in first part of thread " The Puma has 1 filter, part number LR004459" but dealer has supplied the following
LR 30778
Andy
Post #156076 17th Jul 2012 8:26am
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
LR 30778
Andy
That is correct - LR030778 supersedes LR00459. The oil filter for the 2.4 and 2.2 TDCi engines is the same part.
Post #158055 26th Jul 2012 11:37am
Fifth Horseman
[Deleted].
Post #158056 26th Jul 2012 11:39am
Staftly
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Hi there, just got my 110 utility xs, ex-demo with approx 2k miles. Swapped my 08 vogue SE tdv8 during the process, bit of a shock coming out of that, however, have to say I wish I'd done it sooner. Any ideas to the question posed above by Jayaway44, castrol Magnatec A1 for 2.4 vehicles without the DPF, but what about the 2.2's? The castrol website says refer to manufacturer, my local dealer didn't seem to know, then they said they only use Shell anyway. I have asked a few people but have received mixed replies. Any ideas? Thanks and good detail MartinK. Thumbs Up
Post #159651 3rd Aug 2012 12:59pm
wslr
You have to use a Ford M2C934-B like the Castrol Edge Pro 5w30.
Post #159664 3rd Aug 2012 1:41pm
BSA627
Cancelled my 90
I was due to take delivery of a 2012 90 XS today , The vehicle was a dealership demonstrator with 2000 miles, I was perfectly aware of the water ingress and
corrosion issues and had booked it in to have the chassis treated , I own another aluminum car and have always used ACF 50 and had planned to treat the defender the same way i was prepaired to except this even though spending nearly 30 grand.
What has really concerned me was the gearbox issues that i have read about in this forum and how many times members vehicles have been back to dealerships
without the fault being resolved , It would appear that landrover arn't planing any recall may be this is not a widespread problem and i have over reacted in canceling my vehicle.
This is my first post on this forum and i would appreciate your views
Post #180572 31st Oct 2012 10:14am
adiep
Gibraltar 2008 Defender 110 Puma 2.4 SW Alpine White
There is a guy here who reckons that Castrol Syntrans Multivehicle 75W-90 blew up his LR gearbox???
http://reviews.halfords.com/4028/209809/reviews.htm
Are we sure this is the right oil?
Post #192748 11th Dec 2012 3:44pm
Martin
Site Admin
That's talking about the LR gearbox not the Ford/Getrag unit in Pumas - and is only one opinion Shocked  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #192751 11th Dec 2012 3:55pm
superspoons
No issues from mine after a 2000 mile trip to France and back in the heat. Its the one recommended by OPIE oils too.
and as Martin said... Not the same box either. Puma's are Ford unit's. Cheers,
Superspoons
Post #192758 11th Dec 2012 4:22pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Minor addendum to this; my MY11 doesn't use a Torx T50 for the gearbox fill and drain, it uses an 8mm Allen key.
Don't know if LR changed things at some point, but mine definitely aren't Torx.
Pete
Post #209634 8th Feb 2013 9:28pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Hi all,
Using the info on this thread I've just done the change of the engine oil and paper filter.
Although it is stated here that the plastic filter housing should be tightened with a 35Nm torque, the housing itself has 25 -0/+5 Nm printed on the outside (also visible on the photo that Martin posted).
This is what mine looks like:
So I wonder now which value is correct ? Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #250600 10th Jul 2013 9:58pm
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
I have just been giving my 2011 90 hardtop a bit of a going over greasing and changing fluids etc and noticed that the drain on the main gearbox needs a 8 mm hex key. That's no problem, however the filler appears to be a much larger hex, much bigger than anything in my set.....does anyone know the size of this for this year's car? XS Pete stated that his is the 8mm hex for both fill and drain, some were torx.....it seems Ford used anything going when they built these ...
Jonno
Post #278293 31st Oct 2013 4:19pm
AlanH
Australia
Had a new transfer box put in mine at end of warranty as a noise like bag pipes (a little bit anyway)kept getting a bit worse as I drove it. I said engine, cook said g/box and independent said rear axle. The Cook won, the dealer said transfer box.
Anyway as I'd decided to change all the oils at 100K (miles) I thought I'd see what the stealer had used in the new T/Box and how much.
Spot on for level but then they could hardly get that wrong, but the oil was a thick greeny looking Censored which smelt like 85/140 to me.
Searched everywhere and got Castrol Syntrax 75 - 90 universal +
Now to do the main box and I think I'll use the same stuff.
AlanH.
Post #291314 18th Dec 2013 6:23am
