Home > Td5 > 110 Mid-Crossmember Replacement |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17480 |
Yes, sorry, I didn't want to sound critical. With the light weight you were lifting there is unlikely to be a problem but we don't want to lose you!
31st May 2020 11:47am |
Titan133 Member Since: 30 Dec 2016 Location: Dorset Posts: 46 |
I’ve just ordered the YRM crossmember. Seats are out but I’m not sure which piece of floor needs to be removed and which bolts/fixings to remove to do that. Could you advise? —————————— 2004 110 TD5 |
26th Aug 2022 12:51pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
The floor section to remove is the flat plate where the 2nd row passengers' feet go when they are sitting in the 2nd row seats. The fixings are large flange headed screws that tap into plastic "rawlplugs" beneath. The heads on these screws are normally rusted into a state that makes it necessary to grind a slot to accept your biggest flat screwdriver. Therefore they will need to be replaced.
26th Aug 2022 5:31pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 756 |
The rear floor screws are cheaply available in stainless steel.....
26th Aug 2022 5:57pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5865 |
I ended up drilling out my screws for the floor. Maybe with a grinder I could cut off the plastic bits from underneath.
I also replaced; screws with stainless plastic bits the screws go into the rubber strip around the floor plates the bolts for the seat brackets as mine had rusted 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
27th Aug 2022 7:42am |
I didn't have the plastic socket things on my rear front..
I had those "spire nut" clip type fasteners |
27th Aug 2022 12:22pm |
I sit corrected, I did have the metal spire nut thingies. 1999 Defender TD5 110
27th Aug 2022 12:57pm |
Many thanks about the replies concerning the floor panel. I’m going to try and remove it tomorrow (BH Monday). ——————————
2004 110 TD5 |
28th Aug 2022 9:05am |
This morning I finally found time to remove the floor panel, prior to replacing the rear crossmember. I’ve attached a few photos after floor removal and some wire-brushing of the chassis and surrounding items. A few questions though:-
If I understand it correctly, I need to cut the top off the bracket marked with the red arrow in order to slide the new crossmember in? Out of interest, what is the bracket marked with the green arrow? I don’t think it’s used on my CSW. The blue arrows show some corrosion damage, which also includes areas close the 2nd row seat brackets. This looks like a tricky area to replace, assuming the replacement body panel is available. Has anyone else had that corrosion problem? Thanks a lot. Click image to enlarge Click image to enlarge —————————— 2004 110 TD5 |
2nd Sep 2022 12:43pm |
I left that bracket it, I found with a bit of jiggling, I could get it pasted. I think I used a jack to gently raise the floor enough to get it under and in.
I also took the opportunity to treat/paint the top of the chassis rail. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
2nd Sep 2022 1:51pm |
There should be no need to cut the red bracket... The green bracket supports your rear floor.....
Take the rear seat brackets off to reveal the full horror of your problem 😕 |
2nd Sep 2022 2:39pm |
Mine had bimetallic corrosion on the upright section of that panel where the cross-member attaches. You'll need some nylon sleeve bushes and a non-conductive gasket to insulate the new aluminium from the steel when you've replaced the corroded metal. The eBay link in my earlier post on this thread is now out-of-stock, but alternatives exist, like this: https://www.ebay.co.uk/itm/273040937208 |
2nd Sep 2022 3:19pm |
Groan. That doesn’t sound very optimistic! —————————— 2004 110 TD5 |
2nd Sep 2022 6:04pm |
Sorry 😔
Let's hope I'm wrong..... |
2nd Sep 2022 6:16pm |
