![]() | Home > Td5 > 110 Mid-Crossmember Replacement |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 815 ![]() ![]() ![]() |
All the parts and panels are available from YRM.... A 5mm drill and a bunch of pop rivits.
Give it a go! |
Titan133 Member Since: 30 Dec 2016 Location: Dorset Posts: 49 ![]() ![]() ![]() |
I’ll see what they say. They seem a very good supplier. ——————————
2004 110 TD5 |
You will probably end up with something like this
I wouldn’t be averse to doing all that work but my problem is that I need my Defender for work. I can’t keep it off the road for weeks on end. ——————————
2004 110 TD5 |
Ah... That would be a problem, it's not a quick job, especially if you find "extra" stuff that needs attention... Brake pipes and fuel pipes and many other things added to my rebuild, I'm trying to do a thorough job.... I don't want to be doing this job again 😊
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3049 ![]() ![]() |
You might get lucky and find that the crossmember is all that's needed.
When l did my 110 mid crossmember there was nothing else needed attention. l had to cut the corner off those brackets to get the new one in though. |
Polarismd Member Since: 13 Feb 2022 Location: Leicestershire Posts: 62 ![]() ![]() |
It was opportune to read this. We just had a guy killed on his driveway propping his Landcruiser on bricks. Found by his stepson, so, please girls and guys "lets be careful out there". |
