Home > Td5 > 110 Mid-Crossmember Replacement
Page 2 of 3 <123>
lightning
Thank you for the warning.
Bricks can indeed shatter suddenly but this was only a very slight raising of the tub probably a couple of CM before the bolt holes lined up.
Also l wasn’t going under the vehicle at all, and the wheels were still on.
I would still have been better using a piece of wood and will do next time.
Post #834397 31st May 2020 10:28am
Yes, sorry, I didn't want to sound critical. With the light weight you were lifting there is unlikely to be a problem but we don't want to lose you!
Post #834414 31st May 2020 11:47am
Titan133
United Kingdom 2004 Defender 110 Td5 CSW Bronze Green
Re: 110 Mid-Crossmember Replacement
Intercept wrote:
As with many things LR, it started as a little job... The intention was to repair the electrolytic corrosion that had eaten away the aluminium around the body to chassis bolts under the 2nd row seats, adding some inter-metal insulation at the same time to prevent its recurrence. However, whilst doing that I found a 2" hole in the mid-crossmember which couldn't be ignored. Fortunately it is bolted to the chassis but a bit of googling revealed that replacement of this part wasn't much fun because the upstand brackets prevent it from being slid out/in. However, YRM and others sell a version with bolt-attached body brackets which means that the main part can be inserted without body removal. But you do need to remove the floor panel.
https://yrmit.co.uk/product/110-mid-crossm...-defender/
As I'd already spent a good few hours a while ago replacing all the floor fixings the floor removal was easy enough. The worst part of the overall job was undoing/cutting the 17 year old bolts holding the old member in place. After that the installation of the new part was very simple - all the bolt holes were in the right place. One slight complaint of the YRM kit is that some of the supplied bolts are a bit long - see photos, but overall I was impressed with the quality of the product.
I’ve just ordered the YRM crossmember. Seats are out but I’m not sure which piece of floor needs to be removed and which bolts/fixings to remove to do that. Could you advise? ——————————
2004 110 TD5
Post #962962 26th Aug 2022 12:51pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
The floor section to remove is the flat plate where the 2nd row passengers' feet go when they are sitting in the 2nd row seats. The fixings are large flange headed screws that tap into plastic "rawlplugs" beneath. The heads on these screws are normally rusted into a state that makes it necessary to grind a slot to accept your biggest flat screwdriver. Therefore they will need to be replaced.
Post #962999 26th Aug 2022 5:31pm
rustandoil
The rear floor screws are cheaply available in stainless steel.....
Post #963004 26th Aug 2022 5:57pm
excossack
I ended up drilling out my screws for the floor. Maybe with a grinder I could cut off the plastic bits from underneath.
I also replaced;
screws with stainless
plastic bits the screws go into
the rubber strip around the floor plates
the bolts for the seat brackets as mine had rusted 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #963033 27th Aug 2022 7:42am
rustandoil
I didn't have the plastic socket things on my rear front..
I had those "spire nut" clip type fasteners
Post #963048 27th Aug 2022 12:22pm
excossack
I sit corrected, I did have the metal spire nut thingies. 1999 Defender TD5 110
Regards
John M0VAZ
Post #963053 27th Aug 2022 12:57pm
Titan133
Many thanks about the replies concerning the floor panel. I’m going to try and remove it tomorrow (BH Monday). ——————————
2004 110 TD5
Post #963121 28th Aug 2022 9:05am
Titan133
This morning I finally found time to remove the floor panel, prior to replacing the rear crossmember. I’ve attached a few photos after floor removal and some wire-brushing of the chassis and surrounding items. A few questions though:-
If I understand it correctly, I need to cut the top off the bracket marked with the red arrow in order to slide the new crossmember in?
Out of interest, what is the bracket marked with the green arrow? I don’t think it’s used on my CSW.
The blue arrows show some corrosion damage, which also includes areas close the 2nd row seat brackets. This looks like a tricky area to replace, assuming the replacement body panel is available. Has anyone else had that corrosion problem?
Thanks a lot.
2004 110 TD5
Post #963760 2nd Sep 2022 12:43pm
excossack
I left that bracket it, I found with a bit of jiggling, I could get it pasted. I think I used a jack to gently raise the floor enough to get it under and in.
I also took the opportunity to treat/paint the top of the chassis rail. 1999 Defender TD5 110
Regards
John M0VAZ
Post #963765 2nd Sep 2022 1:51pm
rustandoil
There should be no need to cut the red bracket... The green bracket supports your rear floor.....
Take the rear seat brackets off to reveal the full horror of your problem 😕
Post #963772 2nd Sep 2022 2:39pm
Intercept
Mine had bimetallic corrosion on the upright section of that panel where the cross-member attaches. You'll need some nylon sleeve bushes and a non-conductive gasket to insulate the new aluminium from the steel when you've replaced the corroded metal.
The eBay link in my earlier post on this thread is now out-of-stock, but alternatives exist, like this:
https://www.ebay.co.uk/itm/273040937208
Post #963778 2nd Sep 2022 3:19pm
Titan133
Groan. That doesn’t sound very optimistic! ——————————
2004 110 TD5
Post #963800 2nd Sep 2022 6:04pm
rustandoil
Sorry 😔
Let's hope I'm wrong.....
Post #963804 2nd Sep 2022 6:16pm
Page 2 of 3 <123>
