Home > Td5 > Changing fuel filter housing
phillips321
2005 Defender 110 2.5 TD DCPU Belize Green
Hi guys,
How easy do the pipes (2005) come off the fuel filter housing? I need to replace this as the mount has corroded and broken.
Does the cover slide back then clips press it to remove each one?
How easy are the old bolts to remove?
Im planning to take the rear wheel off to make access easier.
Thanks in advance
Post #957609 7th Jul 2022 5:06pm
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
Yes just be very careful as they can become brittle and break. Also the bolts will probably be corroded as well. Changed mine a few years back for a billet type filter housing as apparently the standard ones can become porous
Post #957623 7th Jul 2022 6:17pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
The Gore replacement filter head is much better manufactured than the standard part. However they are £106!
Post #959138 21st Jul 2022 7:02pm
roel
If the original survived 18 years off spray from the rear wheel, I think it is not a bad part. Roel
2003 90 Td5 (2009-now)
Post #959220 22nd Jul 2022 7:13pm
KISSMYAURA
United Kingdom 2003 Defender 90 2.5 TD SW Epsom Green
get a LR replacement, they not expensive!
Post #976456 2nd Jan 2023 8:50pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Give it a good clean up with degreaser and a jet washer. Once nice and clean allow to dry and then soak everything in Plus Gas. Leave for at least 24 hours and then everything will disassemble very easily.
Jim
Post #976531 3rd Jan 2023 11:54am
KISSMYAURA
Thumbs Up
Post #976534 3rd Jan 2023 12:43pm
Linds Hanson
the TD5 filter housing is obsolete from LR now. Just be careful with the aftermarket ones they have been known to blow the pipes off!
Post #976593 3rd Jan 2023 7:18pm
