![]() | Home > V8 > 3UZ-FE conversion |
Timbo Member Since: 15 Jun 2021 Location: west mids Posts: 136 ![]() ![]() ![]() |
![]() Click image to enlarge Decided to change turrets as access was good. 5 minute job right? ![]() Click image to enlarge After much struggling got this far yesterday ![]() ![]() Click image to enlarge Was worth the effort as I think these look great ![]() |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 343 ![]() ![]() ![]() |
Looking good Tim I'll never understand why land rover went the way they did for the turrets
bet youre quite chuffed with how the gear stick arrangement came out, looks brill What exhaust manifold is that? Looks a lot tighter than the one I got for my 1uz 4.0 V8 Defender 90 My Instagram |
I was very pleased with myself the gear lever came up in the right place
The perishing hoses is nothing new is it lol.
I was considering using standard ls400 manifolds but modifying them to fit too, as I haven't seen a lot of options locally for tight fitments or at least more suitable for a setup in a defender. I've seen 2uz manifolds fitted to 1UZs but again I can't find any. What are you doing for the exhaust? I'm thinking of buying a Stainless system from the mid pipe back, and then having just some down pipes made to a Y piece. I've watched a lot of CartuneNZ recently and he recommends a 2"- 2.75" Pipe for optimal torque and drive ability... Then again, I want the noise. ![]() My Instagram |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 490 ![]() ![]() |
Looks great but please tell me you have'nt fitted Terrafirm dampers and springs!
The springs are britpart HD+2" and the shocks are terra firma been on for about 6 years no complaints. That said the near side front needs replacing now I might go for old man emus next. Any objections?
I could tell you but then I'd have to kill you ![]() ![]() |
![]() Click image to enlarge Smaller 2 bolt flange fitted to downpipes ![]() Click image to enlarge Grand daughter helped with welding ![]() ![]() Click image to enlarge Coming back together. I've got this horrible feeling I've forgot something ![]() |
![]() Click image to enlarge Brakes bled, clutch bled, lot's of plumbing done and it's got it's eyes back! ![]() Click image to enlarge Does anybody know if I can plumb header tank into this spigot? Obviously it's blanked at the moment but I can connect to this or T into bottom hose which is better? |
I plan on using the Standard TD5 rad on mine. Don't see why you can't use it. 4.0 V8 Defender 90
My Instagram |
You’ll find it won’t cool it well enough, use a v8 rad.
I was trying to escape buying another radiator.
![]() My thinking was that the difference in size between the TD5 rad and the standard LS400 rad isn’t much. And I’m going to be using a revotec electric fan. I might have a think about it and probably end up saying f### it to the old bank balance ![]() My Instagram |
Do you have a part number for the v8 rad Greeni? My guy wiring it up said the tdci rad which is the same as the td5 rad is not big enough ![]() |
Also he cranked it up with just the manifolds fitted and it's very, very loud
