Home > Technical > Defender not starting
Lmjbacon
United Kingdom 2009 Defender 110 Puma 2.4 XS DCPU Zermatt Silver
Hi! My defender 2.4 puma is not starting, it turns over but will not fire up I had it running yesterday and I had been driving about just fine! I turned it off to hock up my trailer and to grab some lunch to come back and find it would not start it just turn over.
I’ve checked all the Fuses / relays the Battery in key fob it’s has no fault codes and the Rail pressure is fine.
The only thing I can think of is the camshaft sensor is not working?
Post #942310 13th Feb 2022 1:55pm
landy andy
What is the immobiliser light doing ?
Post #942320 13th Feb 2022 2:42pm
Lmjbacon
No red light on the immobiliser when the keys in the ignition. Red flashing light only when I active the key fob to lock and unlocked the truck
Post #942325 13th Feb 2022 3:00pm
Procta
id look at the inertia switch thing, just in case that's tripped, or failed for some reason. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #942776 17th Feb 2022 1:44am
No inertia switch on a Puma (it's a mechanical fuel pump).
Post #942784 17th Feb 2022 7:13am
nitram17
Do you mean on a 2.4 Puma ?Deffo an IS on my MY2015 2014 2.2 Puma
Post #947863 3rd Apr 2022 11:38am
Yes, of course, I tend to forget that the 2.2 went back to an in-tank primary pump.
No IS on 2.4, IS on 2.2 (and TD5).
No IS on OP's Defender.
Post #947865 3rd Apr 2022 12:08pm
nitram17
Thumbs Up Thumbs Up
Post #947884 3rd Apr 2022 2:57pm
