![]() | Home > Technical > Defender not starting |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5815 ![]() ![]() |
What is the immobiliser light doing ?
Lmjbacon Member Since: 13 Feb 2022 Location: Lincolnshire Posts: 3 ![]() ![]() ![]() |
No red light on the immobiliser when the keys in the ignition. Red flashing light only when I active the key fob to lock and unlocked the truck
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5241 ![]() ![]() |
id look at the inertia switch thing, just in case that's tripped, or failed for some reason. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17618 ![]() ![]() ![]() |
No inertia switch on a Puma (it's a mechanical fuel pump).
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Do you mean on a 2.4 Puma ?Deffo an IS on my MY2015 2014 2.2 Puma
Yes, of course, I tend to forget that the 2.2 went back to an in-tank primary pump.
No IS on 2.4, IS on 2.2 (and TD5). No IS on OP's Defender. |
