Home > Maintenance & Modifications > Extended rain gutter |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 |
For your general amusement. Spent a bit of time wondering about the joys of rain water running down the pillars and into the door seals. So new seals fitted and dum dum all of which works rather well . So have if stood in the rain watching it poor out of the gutter down the side and into the seal I thought..,I’d have a play with extending the gutter. I’ve some side panels left from fitting side lockers and window. I wanted something fairly discreet.
Click image to enlarge Click image to enlarge Click image to enlarge Early days yet and it’s only held on the blue tac plan is to finish painting and laquer it then steel weld it to the gram and tiger seal . Initial trial worked ok . |
1st Jul 2021 8:45am |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
See https://www.defender2.net/forum/topic56625.html for info about a solution using 16mm plastic trunking
plus photos from the originator's gallery: Click image to enlarge Click image to enlarge Click image to enlarge |
1st Jul 2021 3:37pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 737 |
Can we see more details on this? The original post I saved no longer has the details and does not make any sense anymore. I've recently been having water in the front passenger side (right side, I'm LHD) I've sealed the roof seams and the windscreen to firewall seam. Even renewed the seals behind the window blocks. For some reason, I'm still getting water in there. I'm hoping this mod, long over due actually, can remedy my problems.
Thanks |
2nd Jul 2021 4:44am |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1833 |
Hardcharger, sounds like your having the same issue I've had previously. Dealer traced is back to water getting in through the heater in take. They sealed around the join circled (badly) in the pic below and fixed the issue
Click image to enlarge 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
2nd Jul 2021 8:35am |
2017 can’t think why I didn’t pick up on that .. oh well my mk 7 is alive and well working well
2nd Jul 2021 8:04pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Its hard to see in that photo ..does that trunking stop the water dripping and sends it back along the guttering? |
2nd Jul 2021 10:22pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1076 |
I don't think so, as the gutter would eventually overflow.
It's more about redirecting the flow. I found a picture of my dum-dum bodge (on the pop-top's lower gutter which is very similar to the original). The water usually takes the orange path and into the door seal. The black lump diverts it along the blue line, you can barely see it, down the A pillar. |
3rd Jul 2021 5:03am |
Nice shot ..mate . That’s the issue I was having having extended the gutter mine now flows out onto the screen and away from the A pillar..
3rd Jul 2021 6:27am |
hi thanks from the picture i wasn't sure if the gutter was open allowing the rain to fall down the screen(white arrow looked like a hole) Very clear now and great mod..what did you paint it with?
3rd Jul 2021 7:03am |
I haven't checked this yet, thanks Rosco, it's now on my to-do list as well |
6th Jul 2021 3:30am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
I've not previously heard of the joint identified in the picture letting water in, but the joint between the duct from the wing to the heater fan box and the fan box itself is notorious for leaking. It has a rectangular foam seal which on many vehicles is squashed flat on one side but doesn't fill the gap on the other.
There are several threads on this joint on the forum. |
6th Jul 2021 7:32am |
Just saw this Grenadier part on LR workshop's youtube channel.
Seems to be a snap-on plastic thingy. Idea for an aftermarket Defender part?! Click image to enlarge |
15th Jul 2021 5:02pm |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
I've just stumbled across this thread, for the avoidance of doubt, is the trunking mod simply to provide something for the water to drip off as shown in blue? I know water has a tendency to track back along the gutter and drip into the footwell (as shown in red).
Click image to enlarge It looks a good little mod, I suppose that a formed return on the gutter (pointing downwards) would have the same effect? 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
14th Mar 2022 9:39pm |
Not sure about that trunking .. mine extends over the rubber .. and since that and sealing the gap between the bulkhead and wing I’ve had two dry footwells ever since.
15th Mar 2022 7:18am |
