Home > Td5 > Adjusting blower direction makes no difference?
phillips321
2005 Defender 110 2.5 TD DCPU Belize Green
Hi all,
I have a 2005 TD5 non aircon model. Regardless of how i adjust the vent slider the vents always blow 50/50 legs and windscreen.
Any idea how i can resolve this?
Thanks in advance
Post #940471 1st Feb 2022 9:28am
Dinnu
I think the Td5 ventilation system is not much different than the earlier models.
On earlier models, there are 2 options:
1. 50/50 windscreen / leg
2. 100% windscreen
Just inside the lower dash, where the leg vents are, there is a flap to shut off the 50% air that goes to the leg area. Probably that is stuck open. You should be able to remove one of the leg vents and check.
The flaps are connected to each other by a metal shaft, so they work together. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #940475 1st Feb 2022 9:57am
kenzle8a
Check the cables that control the flaps, I adjusted mine to ensure they were tight when set to dash only. Also check the seals around the tubes up to the dash vents. I put some duct tape around mine as they were pretty loose.
Post #940490 1st Feb 2022 12:01pm
markb110
Grafty99 came up with a solution in regards to the vents at knee level.
They are made to swivel so you can angle them where ever is best for you and the most effective.
I have them in my TD5 and they are great.
I think that the design was passed onto IRB to retail.
I am sure someone can get you a link.
Thumbs Up
Post #940494 1st Feb 2022 12:21pm
roel
I think your cable/steel wire has snapped like mine.
I didn't bother fixing it yet as mine passed MOT without a problem. Roel
2003 90 Td5 (2009-now)
Post #940541 1st Feb 2022 4:58pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
My Td5 is very much a case of:
Windscreen - 80% windscreen : 20% feet;
Mid - 30-40% windscreen : 60-70% feet;
Feet - 10% windscreen : 90% feet.
I have Grafty’s swivel vents, which are an epic improvement.
In general, it’s a fairly agricultural arrangement from the factory. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #940552 1st Feb 2022 7:17pm
Procta
Re: Adjusting blower direction makes no difference?
phillips321 wrote:
Hi all,
Thanks in advance
Give the cables a bit of a spray down on the heater box in the engine bay, i had a little bit of bother with my 300, been a little stiff. Sprayed those down with WD40 and worked the controls, and it worked wonders. I did the same trick with the TD5 Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #942266 13th Feb 2022 3:08am
