![]() | Home > Td5 > Adjusting blower direction makes no difference? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3478 ![]() ![]() ![]() |
I think the Td5 ventilation system is not much different than the earlier models.
On earlier models, there are 2 options: 1. 50/50 windscreen / leg 2. 100% windscreen Just inside the lower dash, where the leg vents are, there is a flap to shut off the 50% air that goes to the leg area. Probably that is stuck open. You should be able to remove one of the leg vents and check. The flaps are connected to each other by a metal shaft, so they work together. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Check the cables that control the flaps, I adjusted mine to ensure they were tight when set to dash only. Also check the seals around the tubes up to the dash vents. I put some duct tape around mine as they were pretty loose.
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2655 ![]() ![]() ![]() |
Grafty99 came up with a solution in regards to the vents at knee level.
They are made to swivel so you can angle them where ever is best for you and the most effective. I have them in my TD5 and they are great. I think that the design was passed onto IRB to retail. I am sure someone can get you a link. ![]() |
I think your cable/steel wire has snapped like mine.
I didn't bother fixing it yet as mine passed MOT without a problem. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 903 ![]() ![]() ![]() |
My Td5 is very much a case of:
Windscreen - 80% windscreen : 20% feet; Mid - 30-40% windscreen : 60-70% feet; Feet - 10% windscreen : 90% feet. I have Grafty’s swivel vents, which are an epic improvement. In general, it’s a fairly agricultural arrangement from the factory. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5235 ![]() ![]() |
Give the cables a bit of a spray down on the heater box in the engine bay, i had a little bit of bother with my 300, been a little stiff. Sprayed those down with WD40 and worked the controls, and it worked wonders. I did the same trick with the TD5 ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
