Home > Td5 > Tow Bar |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2659 |
No that’s a 110 towbar - from Td5 (1998) onwards they differ, before that 110 and 90 were the same.
On that one the braces bolt directly to the chassis rails where they dip down. On a 90 towbar the braces pick up on the fuel tank cradle brackets rather than the chassis itself. |
25th Jan 2022 6:10pm |
cocker Member Since: 23 Sep 2021 Location: Merseyside Posts: 38 |
so if this has the wrong side braces as anyone by chance got the right ones to fit a TD5 90 ?
26th Jan 2022 11:16am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5740 |
These show you the difference.
26th Jan 2022 12:13pm |
phillips321 Member Since: 16 Dec 2021 Location: UK Posts: 103 |
Fancy selling the 110 side braces? I dont have any
27th Jan 2022 4:14pm |
yes make me an offer still after some braces for my 90
27th Jan 2022 10:37pm |
scotsstag Member Since: 17 Jun 2012 Location: D+G Posts: 535 |
Think I've got some, I'll have a look tomorrow. 04' 90 Td5 CSW..
30th Jan 2022 12:04am |
Thanks Scotsstag that wold be great
30th Jan 2022 9:19am |
These are the parts I have, all brand new and never fitted..
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 04' 90 Td5 CSW.. |
30th Jan 2022 1:53pm |
How much do you want including postage
Peter |
30th Jan 2022 2:55pm |
They won’t fit your Td5 90 - unless it’s some kind of aftermarket bar. You’re looking for the ones in Landy Andy’s post above. Flat steel with a slight bend, not an angle section.
30th Jan 2022 3:50pm |
Make sure they're what you want first... 04' 90 Td5 CSW..
30th Jan 2022 4:12pm |
Thanks for the info will give them a miss thanks to Scotsstag for looking
30th Jan 2022 5:08pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3376 |
Have you looked at fitting a 2inch receiver ?
Same sort of money as a new drop hitch but gives flexibility to fit a tow ball, jaw or nato hitch without adversely affecting your departure angles when not in use. Click image to enlarge Click image to enlarge |
30th Jan 2022 5:17pm |
