Home > Td5 > Tow Bar
cocker
Tow Bar
Hi will this tow bar fit a TD5 Defender 90 ?
and if so were do the side brackets bolt two any pictures would be helpful
Thanks
Peter
Post #939471 25th Jan 2022 6:25pm
Retroanaconda
No that’s a 110 towbar - from Td5 (1998) onwards they differ, before that 110 and 90 were the same.
On that one the braces bolt directly to the chassis rails where they dip down. On a 90 towbar the braces pick up on the fuel tank cradle brackets rather than the chassis itself.
Post #939486 25th Jan 2022 7:10pm
cocker
so if this has the wrong side braces as anyone by chance got the right ones to fit a TD5 90 ?
Post #939556 26th Jan 2022 12:16pm
landy andy
These show you the difference.
Post #939561 26th Jan 2022 1:13pm
phillips321
2005 Defender 110 2.5 TD DCPU Belize Green
Fancy selling the 110 side braces? I dont have any
Post #939746 27th Jan 2022 5:14pm
cocker
yes make me an offer still after some braces for my 90
Post #939796 27th Jan 2022 11:37pm
scotsstag
Scotland 2004 Defender 90 Td5 CSW Rutland Red
Think I've got some, I'll have a look tomorrow. 04' 90 Td5 CSW..
Post #940111 30th Jan 2022 1:04am
cocker
Thanks Scotsstag that wold be great
Post #940137 30th Jan 2022 10:19am
scotsstag
These are the parts I have, all brand new and never fitted..
 04' 90 Td5 CSW..
Post #940187 30th Jan 2022 2:53pm
cocker
How much do you want including postage
Peter
Post #940195 30th Jan 2022 3:55pm
Retroanaconda
They won’t fit your Td5 90 - unless it’s some kind of aftermarket bar. You’re looking for the ones in Landy Andy’s post above. Flat steel with a slight bend, not an angle section.
Post #940208 30th Jan 2022 4:50pm
scotsstag
Make sure they're what you want first... 04' 90 Td5 CSW..
Post #940211 30th Jan 2022 5:12pm
cocker
Thanks for the info will give them a miss thanks to Scotsstag for looking
Post #940224 30th Jan 2022 6:08pm
camelman
Have you looked at fitting a 2inch receiver ?
Same sort of money as a new drop hitch but gives flexibility to fit a tow ball, jaw or nato hitch without adversely affecting your departure angles when not in use.
Post #940227 30th Jan 2022 6:17pm
