Home > Maintenance & Modifications > LT77 to R380 for LS Swap |
darbpunk Member Since: 12 Aug 2018 Location: Oregon Posts: 8 |
Hey guys!
Swapping out my NA 2.5L out of my 95 110. Needing to convert the tunnel to make room for the AX15 trans. Is all I would need for fitting: https://www.roversnorth.com/parts/rna0063k...amp;type=3 Obviously a lot more going into the swap, just curious on having the trans fit in the tunnel. Thx! |
28th Jan 2022 6:06am |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 820 |
Thought I recognised the model as I used to have an XJ (auto not manual). I guess they are plentiful in the States?
https://en.wikipedia.org/wiki/Aisin_AX15_transmission |
28th Jan 2022 3:54pm |
Yeah, solid trans to keep the LS a manual. Will set the engine and trans and then do the conversion. 👍🏻
29th Jan 2022 2:51am |
