Home > Puma (Tdci) > Output shaft failure, Forum Survey
Page 26 of 33 <123 ... 252627 ... 313233>
MK
My bet is that those total losses of drive are not due to the Ashcroft kit failing. I would pay to look at those kits. Puma 110" SW
Post #938336 19th Jan 2022 1:41pm
Dinnu
JLR already knew that the Defender days were countable when they were ending the TD5. So why bother spending a fortune in development and testing... it only need to last as long as the warranty. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #938337 19th Jan 2022 1:57pm
Caterham
if the extension casting was on a budget (which I'm sure it would have been) is if fair to assume some have warped during the casting process?
Post #938339 19th Jan 2022 2:35pm
DSC-off
All of the important features of the adapter casting are machined after casting to eliminate the inaccuracies of the casting process (supposedly). That is, the faces and the locating dowel holes at both ends.
Whether the machining is accurate enough to ensure alignment, or not, is the question here.
Also relevant is the machining of the corresponding features on the back of the gearbox and front of the transfer box.
It all has to go together to achieve an acceptable condition when assembled.
I would suggest that nobody, JLR included, knows what the acceptable limit is for misalignment in this application.
Indeed it is an arbitrary point as to where that limit is, should the life be 100K, 200K miles or more?
The only things we do know is 20K miles or 50K miles is not acceptable, neither is sudden, complete and unpredictable failure.
Post #938350 19th Jan 2022 4:25pm
Caterham wrote:
you'd think LR would be 'man enough' to explain what the problem is and a remedy even if it were at a cost?
You are joking, right? The company with possibly the worst record of any for acknowledging the possibility of faults with its products.
Post #938352 19th Jan 2022 4:29pm
Grenadier wrote:
Good post. It makes one wonder, therefore, if it’s a QC problem? Is there a problem with the angles of the two faces that meet between the MT82 and trans case? Clearly the MT82 was brought in off the shelf to be married to (I think I’m right in saying) the already used trans case. If so, perhaps some light fettling was done (or wasn’t done, but was required) to the trans case in order for it to marry to the MT82 and that the problems stem from what could have been a back-of-fag-packet solution, as was the theme for all later development of the Defender by LR. The angle of the respective faces would only need to be an ‘nth’ of a degree out between top and bottom to stress the OS. Easily done if the work was carried out by hand. Another hypothesis, clearly.
Some/most/all of us have been wondering about a QC issue for over a decade now!
As far as the fitting is concerned the transfer case is identical to any other LT230, it is not modified in any way specific to the Puma. The MT82 is different to (I think) all others since it has a mating face for the adaptor housing and has no propshaft fitted. It is however relatively unlikely that there is any widespread manufacturing issue with the MT82 since generally gearboxes are manufactured to tight tolerances and the MT82 is not a bad gearbox (except for those specially made to annoy Mustang owners by having optional defects built in).
It is most plausible that if there is a manufacturing tolerance issue it concerns the adaptor housing, which is a specific-to-the-Puma part, we don't know who makes it, we don't know the dimensional specification or tolerances, we don't know the QC processes, and it is exceptionally difficult to measure it for accuracy. Any errors in the manufacture of the housing could introduce a number of alignment issues - the gearbox and transfer box shafts axes may be parallel but offset, or they may not be parallel whether or not offset, and any of these or any combination of these will destroy the coupling.
Nige's measuring technique on his video only measure offset, not angular misalignment. It would be difficult to measure the accuracy of this part without manufacturing special (precision) tooling.
Finally we should remember that this is actually all speculation, albeit informed speculation based on sound engineering. Indeed, is there actually a problem at all? Landrover says not.
Post #938353 19th Jan 2022 4:44pm
Is it correct that there's no know failure of the Ashcroft kit?
If that's the case, and their kit does nothing to address any type of alignment issue but rather changes the mating splines from dry to wet, then is it possible to hypothesise that this is the issue?
The fact that the LR instructions make reference to and include grease in the repair kit might also support this notion. Albeit, it does not have a way to hold the grease insitu or replenish (as per the Ashcroft kit) and thus there have been repeat failures?
Post #938358 19th Jan 2022 4:58pm
I don't really think that there is anything to add to the preceding 26 pages of this thread as far as hypothesising on the cause.
Post #938365 19th Jan 2022 5:43pm
MK
There is evidence some shafts disengages and moves backwards from the female adaptor. Puma 110" SW
Post #938366 19th Jan 2022 5:51pm
Caterham
Sheep
I wasn't but I probably should have been. Big Cry
Post #938376 19th Jan 2022 6:43pm
Caterham
FIXED IT.
when replacing your next adapter shaft first get it on a lathe. Cut a groove into the mid-part of the shaft. the groove needs to be deep enough such to introduce some flex. This will allow for any mis-alignment. Thumbs Up
Post #938378 19th Jan 2022 6:48pm
ashtrans
Site Sponsor
The fact that the LR instructions make reference to and include grease in the repair kit might also support this notion. Albeit, it does not have a way to hold the grease insitu or relish (as per the Ashcroft kit) and thus there have been repeat failures?
I would agree with this, we don’t fix the misalignment, we just wet the spline so it doesn’t wear out as the spline faces rub with each revolution. Dave
Post #938381 19th Jan 2022 7:16pm
nitram17
Caterham wrote:
FIXED IT.
Is it April 1st?
Post #938383 19th Jan 2022 7:25pm
nitram17
Re: Bloody Output Shaft
natyeo wrote:
My 2014 2.2 90 HT at 127689 has just lost all drive , after fitting the Ashcroft kit in my 2012 90 , do I go the same route A) Ashcroft or B) do I go std land rover and drill and tap fit grease nipples 180 degrees apart and my acccess hole in casing or C) std landrover and fill with good grease?
Thoughts Folks
The guy who tapped his shaft (steady matron)and fitted grease nipples i don't think is on the forum anymore ......so no update ..i wonder if anybody else has done it?I wondered also if it was worth drilling and tapping two high tensile bolts at 90degrees to the grease nipples to minimize movement and extend life of shaft.
Post #938386 19th Jan 2022 7:46pm
nitram17 wrote:
Caterham wrote:
FIXED IT.
Is it April 1st?
No, but I fear Caterham's come off his meds too soon! Rolling with laughter
Post #938396 19th Jan 2022 8:24pm
