Home > Puma (Tdci) > Output shaft failure, Forum Survey
Page 27 of 33 <123 ... 262728 ... 313233>
nitram17
His local pharmacy may go out of business!
Post #938406 19th Jan 2022 10:16pm
Caterham
Shocked
I guess that wouldn't work Confused
Rolling with laughter
Post #938543 20th Jan 2022 6:28pm
Jpw110xs2015
Gbox op shaft failed 32k miles.
Looking for best advice, replacement os for 2.2 puma 110 defender , ashcroft or Lof ?
Post #938848 22nd Jan 2022 4:41pm
Dinnu
My opinion, if it failed at 32k miles, go for Ashcroft. Thats because it can allow a bit more misalignment, and if it has to go again, you replace the shaft only, not the gearbox or transfer case. There is no information/data of what happens with a solid shaft when there is misalignment. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #938851 22nd Jan 2022 4:54pm
Jpw110xs2015
Dinnu, thanks for the feedback. I guess any replacement will be stressed if misaligned.
Post #938862 22nd Jan 2022 6:08pm
Dinnu
That is the hypothesis. Some Defenders can reach very good milage, some not, and the most plausible root cause is misalignment between the gearbox and the transfer case. These are mated with an adaptor housing, both ends are doweled, so most likely some had higher inaccuracies than others. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #938880 22nd Jan 2022 7:47pm
Jpw110xs2015
Dinnu, I appreciate your knowledge and explanation, 110 currently in the garage, I will discuss with the technician tomorrow morning, once again thanks.
Post #938957 23rd Jan 2022 11:04am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Report post
1. 2011 90HT
2. 2.4
3. Y still original
4. 60k miles Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #938961 23rd Jan 2022 11:42am
Jpw110xs2015
2015 110xs os failed 32k miles
Post #938966 23rd Jan 2022 12:12pm
Siwynne
It is four years since I posted in this thread. Five years since the shaft was replaced Og shaft was replaced at 40k with genuine parts. Now on 112k and all good. Alignment will be the same so why has one lasted so much longer than the other?
Post #939039 23rd Jan 2022 6:06pm
Caterham
thanks for throwing that in and ruining our theories Evil or Very Mad
Mr. Green Thumbs Up
interesting
Post #939040 23rd Jan 2022 6:09pm
Mr. Green Thumbs Up
interesting
Whose theories?
Maybe all theories are not equal?
Genuine replacement included grease...factory install excluded grease, Ashcroft solution is to wet a dry spline.
Go figure...
Post #939041 23rd Jan 2022 6:09pm
blackwolf wrote:
I don't really think that there is anything to add to the preceding 26 pages of this thread as far as hypothesising on the cause.
Other than stating the obvious?
Post #939042 23rd Jan 2022 6:18pm
Caterham
you may find there's a very large number of wet installs that have failed.
take my second failure for example.
Post #939046 23rd Jan 2022 6:24pm
Can you be more specific ~ who's wet install?
Post #939049 23rd Jan 2022 6:28pm
