Home > Puma (Tdci) > Best 2-stroke?
ZeDefender
Best 2-stroke?
Okay - I'm taking the plunge and experimenting with 2-stroke in the diesel for my Puma this winter. Have read about this in other threads but get mixed messages. So -
Can anyone recommend type/manufacturer for the oil?
Also interested in this Forte stuff - any advice on that?
Cheers,
Matt Tell someone you love them today because life is short.
Post #93174 7th Oct 2011 5:50pm
rossy
for a diesel additive to be of any use the benefeits need to be measurable otherwise its just an expensive snake oil/placebo situation. There are thousands of posts on this subject across the net so I suppose you can only go by people's experiences and then make a decision.
I decided to use 2SO on a previous vehicle and after 6 months I saw better mpg, stronger performance and an end to 3 years of engine problems (gunged up sensors mostly) so in my situation it was measurable. I have used it from new in my 110 so I can't prove its worth from a 'before and after' basis (whoops ! B'n'A is banned phrase on Def2 Laughing )
As regards spec in my experience Jaso FB or FC is fine - whichever you can get cheapest. There are debates over the pros and cons of both but to avoid boring you any more the 2.4 Puma has no DPF and its CAT is a simple 2 stage affair so I don't think it matters which one you use. Hope that helps but on the subject of 2SO you'll find that opinions are definately arseholes - everyone will have one !
Post #93188 7th Oct 2011 6:56pm
pannawonica
Australia
I gave the 2 stoke a go about a week back. To be honest I cannot comment on power or economy, however I have noticed that the engine sounds quieter and smoother. I used cheap mineral based oil, low ash which will burn completely away. Doubt that @ 300mills in 70 litres will cause any problems if it reduces friction in the fuel system it may actually reduce heat. If it increases the cetane valve of the fuel it has to be a good thing.Maybe someone with more knoledge could comment. Thumbs Up
Post #93226 8th Oct 2011 6:00am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
So 230/1 mix ratio, is the this the common ratio? Original Member Pie n Pea Club.
110 HCPU Tipper
Post #93227 8th Oct 2011 6:23am
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I do 200/1 and use Yamaha outboard oil on both my TD5 and Puma. Yes both seem to run better and make less noise. No smoke and smell lots better. I would not run either without again.
Allan
Post #93230 8th Oct 2011 7:08am
pannawonica
Australia
I would like to add that I also have no smoke before and after ( opps Whistle ) adding the oil. I have a Alive remap it has never blown any smoke, no visible difference between it and standard map!
Post #93234 8th Oct 2011 7:38am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Castrol Actevo FC Thumbs Up
Post #93235 8th Oct 2011 8:00am
rossy
yep XS pete thats what I'm using at the moment cos I got 5 bottles for € 5 each from a local farmer's co op and that's cheap !
Post #93236 8th Oct 2011 8:08am
pom
i use it, may be placebo but is 'does' sound quiter, i dont really monitor mpg as it would just annoy me!
Pom
Post #93240 8th Oct 2011 8:22am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I have got to pop over to Halfords latter will the Halfords Low ash, mineral garden machinery 2 stroke do or should I go for the more expensive products and if so which one?
http://www.halfords.com/webapp/wcs/stores/...nce%7C%7C0
Post #93244 8th Oct 2011 8:41am
ZeDefender
What do FB and FC stand for? I can only get Castrol Act evo 2T here (2T = 2-Takt = 2-stroke)
They are all mineral-based Question
Duh, sorry, just read it exceeds Jaso FC (guess that's the "FC" then) Embarassed
Cheers,
Post #93248 8th Oct 2011 9:09am
rossy
Ze defender maybe do a normal google search to find out the differences between the two as there are reams of techno stuff on it.
The way I understand it is that FB = mineral based low ash. FC= semi synthetic and even lower ash than FB. The FC however may not burn as fully as the FB being semi synth although its recommended for DPF engines due to less ash residue which to me translates as swings and roundabouts so I buy whatever is the cheapest ! Wink
Post #93257 8th Oct 2011 11:14am
Lorryman100
There are pages of info on this on here,
http://www.defender2.net/forum/topic1708.html
Personally I use the cheapest JASO FB mineral oil that I can get a deal on. I prefer the Motul from OPIE oils and it is a good price Thumbs Up
http://www.opieoils.co.uk/p-928-motul-100-...gines.aspx
Brian.
Post #93261 8th Oct 2011 11:24am
ZeDefender
Okay - have finally settled on FB not FC (to protect my cat).
Motul 100 Motomix 2T was my choice (I like Motul products, as you may have gathered)
I'll use 250 ml per 65 l fill-up (about 1:250).
Go-on, just tell me I'm wrong, I dare you! Evil or Very Mad
Thanks to all Thumbs Up
Post #93267 8th Oct 2011 12:24pm
ZeDefender
... but hang on - I've got Castrol Act evo 2T in my garage and it's also supposed to be "mineral" and its FC???
May have just needlessly bought the Motul... Big Cry Tell someone you love them today because life is short.
Post #93270 8th Oct 2011 1:00pm
