![]() | Home > Puma (Tdci) > Best 2-stroke? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4742 ![]() ![]() |
FC for the Puma owing to the catalytic converter.Castrol Actevo seems most suited as it is mineral based and up to FC spec. 1982 88" 2.25 diesel
Aahh - I think you mean if you add 2SO in general? How much more often for the engine oil changes? Cheers, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... Last edited by ZeDefender on 8th Oct 2011 1:52pm. Edited 1 time in total |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
Use TCW-3 mineral marine two stroke.It's low ash and burns at lower temp.The mineral oils mix and become one with diesel with no separation.If you can't get mineral use semi-synth. Puma 110 SW
90 V8 SOFT TOP |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2454 ![]() ![]() ![]() |
Based on 2 analyses on 913C, not more than 7kkm Puma 110" SW ............................................................. Earth first. Other planets later |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
For which reason engine oil must be replaced with shorter frequency ? |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 ![]() ![]() ![]() |
I use the Actevo too.
According to the German bloke who started the whole 2so debate over on another forum, the optimum ratio to add to the diesel is 1:200. On a 110 this equates to approx. 330ml. I measured this amount out (using water) in a screw top clear plastic drinks bottle, marked the level, dried out the bottle, and now keep one 'dose' measured out and ready each time. BTW, Halfrauds charge £8.99 for a 1litre bottle. Nielsen CDG (google it) charge £4.85, or £4.55 if you order 16 or more! About to see if Opie can match that! :-) ![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
Correction - Nielsen's £4.85 price is for 12 or more. I buy in bulk! Extra 30p off comes if you buy 16 or over.
Otherwise it's £5.99. ![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
scottish110 Member Since: 10 Nov 2011 Location: Inverurie Posts: 363 ![]() ![]() ![]() |
did you see if opie could do better than nielsen could do on 12 bottles ? |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 ![]() ![]() ![]() |
I've used some Castrol 2stroke oil, JasoFB ... 250ml/70L fuel ... 2l toal, 8 diesel tanks
It's quieter, I think, but my L/km (Mpg) is the same ... I'll keep using it! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
