Home > Puma (Tdci) > Best 2-stroke? |
Okay - I'm taking the plunge and experimenting with 2-stroke in the diesel for my Puma this winter. Have read about this in other threads but get mixed messages. So -
Can anyone recommend type/manufacturer for the oil? Also interested in this Forte stuff - any advice on that? Cheers, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
7th Oct 2011 6:50pm |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
I gave the 2 stoke a go about a week back. To be honest I cannot comment on power or economy, however I have noticed that the engine sounds quieter and smoother. I used cheap mineral based oil, low ash which will burn completely away. Doubt that @ 300mills in 70 litres will cause any problems if it reduces friction in the fuel system it may actually reduce heat. If it increases the cetane valve of the fuel it has to be a good thing.Maybe someone with more knoledge could comment.
8th Oct 2011 7:00am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
So 230/1 mix ratio, is the this the common ratio? Original Member Pie n Pea Club.
110 HCPU Tipper |
8th Oct 2011 7:23am |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 |
I do 200/1 and use Yamaha outboard oil on both my TD5 and Puma. Yes both seem to run better and make less noise. No smoke and smell lots better. I would not run either without again.
Allan |
8th Oct 2011 8:08am |
I would like to add that I also have no smoke before and after ( opps ) adding the oil. I have a Alive remap it has never blown any smoke, no visible difference between it and standard map!
8th Oct 2011 8:38am |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Castrol Actevo FC
8th Oct 2011 9:00am |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
yep XS pete thats what I'm using at the moment cos I got 5 bottles for € 5 each from a local farmer's co op and that's cheap !
8th Oct 2011 9:08am |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
i use it, may be placebo but is 'does' sound quiter, i dont really monitor mpg as it would just annoy me!
Pom |
8th Oct 2011 9:22am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
I have got to pop over to Halfords latter will the Halfords Low ash, mineral garden machinery 2 stroke do or should I go for the more expensive products and if so which one?
http://www.halfords.com/webapp/wcs/stores/...nce%7C%7C0 |
8th Oct 2011 9:41am |
What do FB and FC stand for? I can only get Castrol Act evo 2T here (2T = 2-Takt = 2-stroke) They are all mineral-based >>>>>>> Duh, sorry, just read it exceeds Jaso FC (guess that's the "FC" then) Cheers, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
8th Oct 2011 10:09am |
Ze defender maybe do a normal google search to find out the differences between the two as there are reams of techno stuff on it.
The way I understand it is that FB = mineral based low ash. FC= semi synthetic and even lower ash than FB. The FC however may not burn as fully as the FB being semi synth although its recommended for DPF engines due to less ash residue which to me translates as swings and roundabouts so I buy whatever is the cheapest ! |
8th Oct 2011 12:14pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
There are pages of info on this on here,
http://www.defender2.net/forum/topic1708.html Personally I use the cheapest JASO FB mineral oil that I can get a deal on. I prefer the Motul from OPIE oils and it is a good price http://www.opieoils.co.uk/p-928-motul-100-...gines.aspx Brian. |
8th Oct 2011 12:24pm |
Okay - have finally settled on FB not FC (to protect my cat).
Motul 100 Motomix 2T was my choice (I like Motul products, as you may have gathered) I'll use 250 ml per 65 l fill-up (about 1:250). Go-on, just tell me I'm wrong, I dare you! Thanks to all Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
8th Oct 2011 1:24pm |
... but hang on - I've got Castrol Act evo 2T in my garage and it's also supposed to be "mineral" and its FC???
May have just needlessly bought the Motul... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
8th Oct 2011 2:00pm |
