![]() | Home > General & Technical (L663) > Defender rattle! |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4784 ![]() ![]() |
It was probably a learning curve for the garage staff aswell. Should be a discount for acting as a guinea pig.
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
MikkoM Member Since: 07 Jun 2021 Location: Uusimaa Posts: 9 ![]() ![]() |
New issue recorded:
SSM75423 - L663 “Distortion” or “rattle” noise present while using the audio system If you experiece with some bass notes rattle/distortion with the front speaker, apply some pressure in the lower speaker grille and it goes away so it is issue with the fixing or door card (with Meridian audio) This issue manifested to my P400e S. MY22 Defender 110 P400e S |
250110hardtop Member Since: 23 Sep 2021 Location: Cork Posts: 3 ![]() ![]() ![]() |
Hi guys ,this video seems to have been taken down , i have the issue now and im not sure which seal is the offender. Has anyone any pics or video that might help. Is it the hard window seal or the rubber outer door seals against the frame that is causing it ? |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Rubber seals in the radiused top left corner should have been stuck to the metal behind it but LR appears to have used cheapo double side sticky pads that loose their adhesive properties over a short time.
On the outside,drop the glass to reveal this curved bit ![]() Click image to enlarge Peel back the curved seal on the inside of the door and apply some adhesive behind the curved rubber on the “outside” of the radiused seal - you may find like me that the OEM double sided sticky pad falls out if it was even there in the first place! Do the same for all the windows ![]() Click image to enlarge I hope this helps Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Tim i really am very thankful, this sorted my issue and was driving me absolutely nuts. Appreciate the time taken ,to get the pics taken and posted.
