![]() | Home > Maintenance & Modifications > Fox 2.0 resevoir shocks |
Can you do pin pin on the rear using any front dampers or just foxes?
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
Yes any fronts will do. I believe the Gwyn Lewis kits with ome shocks are all pin-pin.
felixp Member Since: 29 Oct 2020 Location: Bavaria Posts: 39 ![]() ![]() |
I've got the same shocks installed and some roost shields coming my way after worrying that something could break... how exactly did you have modify yours in order to fit? Thanks! |
Yes you are right they are pin-pin all around. Great and simple system that works. ![]() |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
first of all, you need the adapters, prolinx supplied mine, they were the prototypes... are you running remote res? that's when its fun (like mine) if they are standard you should be good to go with the adapters. I'd say these are a easier bet... https://www.prolinx.biz/Catalogue/Shock-Ab...GUARDBOOT2 |
Thanks! I got the remote ones installed.. can you tell me what exactly these adapter do?
Take a look here…
![]() The adapters go on the end of the shaft so you have something to mount the shields too. Otherwise they don’t grip / stay on the shaft On the fronts it’s a nightmare, plenty of dremel work was involved to get it to fit with my setup… it’s all adrenaline 4x4 / Gwynn Lewis now |
Ahice Member Since: 28 Nov 2021 Location: VA Posts: 2 ![]() ![]() |
Awesome set up - looking to do something similar but trying to decide if I want to go with a pin pin rear with a longer remote reservoir or normal rears. Can you share the shock part number you used for the rear? |
They’re just the standard fronts.
https://www.prolinx.biz/Catalogue/Shock-Ab...FRNTPSSTDA |
Thanks! I must have missed it in my reading of the thread.
