Home > Maintenance & Modifications > Fox 2.0 resevoir shocks
Page 6 of 9 <123456789>
keith
Having a quick online search Iv seen many full rubber ridged covers for other shocks that would do the job with a tie clip to secure. Iv also found Velcro covers but out with the UK. I might even see if my existing plastic covers will be able to be used.
Post #827053 22nd Apr 2020 5:43pm
Likeomg
Only problem is moisture build up etc, prolinx (who import fox in the uk) have some but they are for competition use only so after each event they are removed and clenaed,
this is who i got the washers from to make them hopefully fit.
Post #827058 22nd Apr 2020 6:05pm
keith
Are the washers currently being used top and bottom, not able to be used again with the fox? Haven’t had a chance to look at them yet though.
Keith
Post #827059 22nd Apr 2020 6:24pm
Likeomg
Mine came without any nuts or washers... not exactly impressed opening a 360 quid rear shock that didn't come with new nuts / washers... alive did say they'd send some but never got any.
saying that i've been meaning to buy these
which i will right now...
https://yrmit.co.uk/product/316-stainless-...r-classic/
while your at it don't fancy some adreneline 4x4 turrets so you can see the fox's in the wheel arch?
Post #827062 22nd Apr 2020 6:29pm
Likeomg
Taxed the car and first thing I did was install the roost shields, but of engineering required due to the remote reservoir, not made easy by both my ramps being blocked with non running cars but managed to protect the shafts anyway.
Post #843554 13th Jul 2020 8:50pm
Co1
I’m pretty sure this is a must. When I look at mine they are cacked in stone chips. I’ve managed to get one replaced on warranty which is great, but it’s an inevitable flaw in design. They should come with the shields by default.
Post #843563 14th Jul 2020 5:03am
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
I have these shocks as well and now you have me concerned.
Has anybody managed to source a supplier of these shields in the UK?
Thanks 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #843573 14th Jul 2020 7:06am
Likeomg
Yeah few chips in the shafts can eat away at the seals then the dampers will be leaking in no time at all...
Post #843620 14th Jul 2020 9:30am
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Prolinx sell the damper shaft guards in the UK
https://www.prolinx.biz/Catalogue/Shock-Ab...uards-pair
Post #843633 14th Jul 2020 11:06am
Likeomg
Prolinx supplied me with the washers you need to fit the shaft guards, otherwise it won’t work
So make sure to ask for these when you buy the shaft guard... I’ll get a pic later
Post #843644 14th Jul 2020 12:04pm
MJN110
I have just been onto prolinx and they say the washers that were provided were experimental only and they dont have anymore.
They are waiting on feedback to see if there is any demand for them? 2016 Defender Landmark 90
Post #843667 14th Jul 2020 1:43pm
Co1
Nice one. Just ordered a pair.
Post #843727 14th Jul 2020 5:49pm
MJN110
It was suggested procomp boots may do the job. 2016 Defender Landmark 90
Post #843765 14th Jul 2020 8:11pm
Co1
Daft question, but I assume you have to remove the shocks to fit the guards? I can get a screw driver into the back of them off not??
Post #844579 18th Jul 2020 6:02pm
Sulisuli
Interesting read, will follow with interest Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #844589 18th Jul 2020 7:39pm
