Home > Maintenance & Modifications > Fox 2.0 resevoir shocks
Page 2 of 9 <123456789>
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I’m interested in how you’ve got on also .. just taken my fronts off to change the springs for some new Alive comfort springs and found that one of my B6’s is knackered.
Need to make a quick decision on either new B6s again or a set of something else .. what do you recommend
(Lowered by -1 and 99% on road use) 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #783274 26th Jul 2019 7:29pm
Sulisuli
I have chosen Alive -1 springs and they recommended the Fox non reservoir dampers for my 100% on road these were recommended over the bilstein dampers I first thought I would be ordering Thumbs Up
These are all being fitted a week tomorrow very much looking forward to the lowered look and the improvement of the HT springs currently fitted.
Hope this helps Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #783277 26th Jul 2019 7:46pm
carrotbay
Where have you got the Fox dampers from .. Alive? 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #783278 26th Jul 2019 7:48pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Likeomg wrote:
It’s more of a show car / tow car / throw the bikes on roof
Heart is set on remote reservoirs... I really did contemplate the adjustable rears for when towing the boat about 2.6 ton unloaded...
They look great, Ive been looking at getting some. After speaking to more knowledgeable folks than myself, the general opinion was the adjustable shocks are the ones to go for but they must be set up properly to get the best out of them.
Post #783279 26th Jul 2019 7:56pm
Sulisuli
Yes the complete suspension package came from Alive included the anti roll bar upgrade Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #783286 26th Jul 2019 8:48pm
Sulisuli
Zed you know you want them Rolling with laughter Rolling with laughter myself and Roy5695 think you should get them!! 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #783287 26th Jul 2019 8:49pm
Zed
Yeah you both are right and if I'm honest with myself it's not really if but when...
Trouble is my to-do list keeps changing as I get distracted by new shiny stuff.
Post #783300 26th Jul 2019 9:00pm
JOW240725
If you haven't seen already, John Fair has the adjustable Fox remote reservoir.... pg. 7 onwards. https://www.defender2.net/forum/topic46611-90.html James
Instagram @suffolk_rovers
Post #783316 26th Jul 2019 9:36pm
Likeomg
I will be getting them once im back in the Uk, still another 6 weeks....
Post #783431 27th Jul 2019 4:26pm
Caterham
Re: Fox 2.0 resevoir shocks
Likeomg wrote:
Seems a bit daft but its something i've like the idea of for a long time,
I currently have bilstein b6 on my defender with -1" springs from alive the 'sport' springs,
Would the 0-1" shocks work with it being lowered?
Im thinking getting the remote res, non adjustable im currently stateside and these are my options for a defender, i have plenty of luggage capacity for bringing them back...
perhaps you could bring me back a couple of AR-15........or shouldn't I even ask that on an open forum Shocked
Post #783448 27th Jul 2019 6:05pm
Caterham
back on subject - they're a lot of Wonga. they look nice but could that money be better spent elsewhere ?
Post #783451 27th Jul 2019 6:07pm
Likeomg
Such as Question
Post #783559 28th Jul 2019 4:00am
doncarloz
Austria 2015 Defender 110 Puma 2.2 DCPU Stornoway Grey
Radflo?
Post #783568 28th Jul 2019 8:38am
Matt110
We tow regularly with our 130, 3.5T plant trailer and with or without load in the rear bed, we run the standard fox non-remote-res shocks all round on it.
The towing is fairly irrelevant. It's always 100-150Kg on the ball, which oscillates up and down due to road loadings so you get a cyclic loading up to say 300Kg. It's a contributor for sure, but it's more the overall load variation that causes the issue.
Empty, they perform admirably, very smooth ride only hampered by the spring rate, but with softer springs they're outstanding shocks (also fitted to our 90).
Loaded, they're under damped in low speed compression, so you tend to get wallow. We have had a number of shocks, they're all the same as they're rarely tuned for the heavier end of the axle load, and the "mid range" tuning tends to mean they're never masters of all trades.
Our feedback would be to buy the adjustable low speed compression damping, that way you can adjust a few clicks up when under heavy load, and back down again for comfort when not.
We are totally converted to Fox shocks, believing them to be outstanding.
We have had one failure, due to the bolt that goes through the bush fatigue failing due to side loading through the bush. The design of the replacement parts we got has changed, so that shouldn't be a problem.
But if you have had fox shocks for a while, the chances are you will have the same issue. make sure the lower shock nut isn't so tight that the bush is side loading the lower bolt (rear shocks). Micro cracks appear in the protruding thread and eventually they fail.
To be honest that's good practice on any shock with pin through bush design, just that our issue came up on a fox part.
Post #783741 29th Jul 2019 10:09am
hank
I seldom tow but agree that unladen they're lovely. Also agree that my previously fitted 'heavy duty' springs were the weak link in my setup, far too hard for a light rear end. Switching to a lower spring rate (CSW white/green/green RKB500300 springs) resulted in a silky rear end with the standard Fox non remote reservoir shocks > 110 XS Double Cab
Post #783752 29th Jul 2019 11:01am
