![]() | Home > V8 > 3UZ-FE conversion |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 343 ![]() ![]() ![]() |
Oh my...
Looks like quite the task at hand ![]() I think I'll be taking my time now ![]() ![]() The only problems I have is getting my hands on all the kit ![]() My Instagram |
Timbo Member Since: 15 Jun 2021 Location: west mids Posts: 136 ![]() ![]() ![]() |
Take everything you can from GS430. I think it was just a different accessory level to the LS430 but engine is the same. Stop faffing around and start leading the way!
![]() I'm looking now at modifying the engine mount brackets on the engine to suit the original mountings on the chassis which are at different heights because Land Rover like to make things difficult ![]() Keep smiling ![]() |
I KNOW I KNOW
![]() I'm doing my best ![]() jokes aside It'll be very soon I get my hands on an engine or donor (Pay day last week... ![]() I did get the chance to look at a mates 1UZ he has at a unit and the mounts look ideal ish for the TD5 chassis, here hoping ![]() If not we've got our selves a welder ![]() My Instagram |
Initially I thought existing mounts lined up but on my chassis they don't
Some bad luck there Tim, bloody hell. You've practically almost doubled your work
![]() at least you’re busy I suppose ![]() I'll be sharing little snippets of the rebuild of the engine for a couple weeks and then after that we should be coming close to the more interesting bits, like the ECU and Loom.... 4.0 V8 Defender 90 My Instagram |
The ECU and loom bits are the bit's where I hold my hands up in surrender
If I need to mate I shall, I know hes abusy bloke. But Im still going to be rolling with Pheonix for the loom and stand alone.
If you have the time, there is a mechanic or "tuner" on YouTube who’s very knowledgeable on the Uz's called CarTuneNZ. He has a heap of information on all aspects of these engines and has made a video about running the engine on the standard ECU with a manual box. I never watched it all but he basically proves its possible running a 1/3uz without the need for a standalone. ![]() My Instagram |
Sorry about lack of posts christmas, covid and family stuff meant progress was slow. Here I'm trimming the bulkhead as it's in the way, may not be enough but hopefully this weekend will answer that question.
![]() Click image to enlarge Re-routing brake and clutch pipes as they are in the way too ![]() Click image to enlarge ![]() Click image to enlarge This is a YRM tank guard / cradle fit's no problem. Tank refitted and new fuel lines are ready to route ![]() Click image to enlarge |
![]() Click image to enlarge ![]() |
Hey Greeni! Which adaptor plate did you plump for? I'm guessing PMC? Also which gearbox are you using? Any advice for this conversion will be gratefully received ![]() |
[quote="Defendermatt"]Looking good! Glad to see you've made some decent progress
![]() Hey Matt thanks again for kit you are a star! I'm still undecided as to what ECU to use if you can give me an idea on price (If you want to get involved ![]() |
It’s a Syncro’s conversion for the r380, it’s one of two that are currently being done at DT Engine Solutions.
There’s also a 1uz with a supercharger on it! |
Fabulous work there timbo
ooof! Sound ![]() ![]() |
