Home > Puma (Tdci) > Puma 110 Fuel Tank Capacity ???
Page 2 of 2 <12
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Quote:
In Greece we have bigger tanks Rolling with laughter
Shocked Either that or dodgy pumps Wink Laughing
Max I ever filled up was 66L, once, getting nervous already Embarassed because of a childhood trauma: my parent's Ford 12m ran out of fuel in the middle of nowhere!, namely the vast voids of a German motorway in the 1980...
Post #912533 15th Jul 2021 5:49pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Pretty regularly I put 70 litres in mine, but that’s shortly after the light comes on. I’ve never pushed it further! Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #912562 15th Jul 2021 7:17pm
Angus_Beef
Correction, in the spirit of transparency.
On the past year, one time I put in 69l
Β―\_(ツ)_/Β―
Post #912592 15th Jul 2021 9:41pm
HardCharger
2.2 Pumas have bigger tanks at about 75 liters as per the specs in the brochure.
2.4 Pumas, for some reason, have smaller tanks at about 73 liters as per the specs in the brochure.
I have a 2.4 Puma and the most milage I had from full to 1/4 left in the tank is about 600 kilometers give or take. Half tank is almost always at 300-ish kilometers. I've never run the tank below 1/4 to empty. The only time this happened to me is when I picked up the truck from the car lot I bought it from and it was nearly empty, probably to prevent any car thieves from getting to far with it. I was stuck in a slow moving traffic jam and had to pull into the first service station I saw to give him his first full tank of diesel under my care. Thumbs Up
Post #912616 16th Jul 2021 4:45am
lolo
Switzerland 2008 Defender 110 Puma 2.4 CSW Keswick Green
We still do not have a definitive answer to the capacity question...
What I can state is that in my Puma 2.4 I just filled it up right after the reserve light came on: 71 liters.
Manual says that there is about 9 liters in the reserve.
We might infere that the capacity is 80 liters.
For info here are the milage at each gauge level I have observed driving on highway at about 2250 rpm with some push at 2500 rpm, mostly in 6th gear, and when I had to down shift for traffic jams and than re accelerate I almost always gear up around 2250 rpm:
1/4: 250km
1/2: 450km
3/4: 620km
3/4+50%: 700km
Reserve light on: 760km, fill up with 71.00 liters. Average 9.3L/100km at a cruising speed 105kph
Post #965239 16th Sep 2022 4:28pm
2.4 Pumas, for some reason, have smaller tanks at about 73 liters as per the specs in the brochure...
Curious, given that the part number is the same for a 2.2 and 2.4 as far as I know, and there is more stuff inside the tank on a 2.2 (specifically a fuel pump) which means it must hold less fuel!
It is, I think, most likely to be random piffle and guesswork in the brochure.
Post #965241 16th Sep 2022 4:44pm
Jonothethird
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
Probably a stupid question, but is the 90 fuel tank smaller? Anyone know how big it is?
Post #965263 16th Sep 2022 10:26pm
AMBxx
The 90 fuel tank is smaller, I can't remember how much smaller. When I had a 90, I easily managed 320 miles at 30mpg. In my 110, I get 400 miles at 28mpg, so quite a bit smaller.
Someone who knows much more than me will be along shortly.
Post #965317 17th Sep 2022 7:35pm
Simonfish
Australia
the D90 fuel tank is 60litres. well, it is in the Australian version anyway.
Post #970938 13th Nov 2022 4:04am
Page 2 of 2 <12
