Home > Puma (Tdci) > Puma 110 Fuel Tank Capacity ???
TJ101
What the most you have ever got into your 110 tank ??
Just towed the race box over to Belgium, and got very low before finding a fuel station
What do you recon it took to fill up ???? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #15455 14th Sep 2009 7:39pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
68L ????
Post #15458 14th Sep 2009 7:51pm
TJ101
Sonic3d wrote:
68L ????
Wrong Rolling Eyes California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #15460 14th Sep 2009 7:54pm
Glynparry25
Hmmmmm,
Tank capacity is 75l, so how about 72litres?
Glyn
Post #15461 14th Sep 2009 8:02pm
TJ101
Glynparry25 wrote:
Hmmmmm,
Glyn
Well my handbook says 73 lts,, the LR website says 75lts
Both wrong Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #15462 14th Sep 2009 8:04pm
110SEB
I'm the kind of guy who'll drive on vapours (even though it's a bad idea in diesels) - i reckon with it filled up through the pipe to the brim 77 litres?
Post #15463 14th Sep 2009 8:26pm
alantd
Most I've ever got in mine is 68L (obviously some in the tank) One that started out as a 2.4 TDCi 110 XS
Post #15464 14th Sep 2009 8:45pm
TJ101
Close enough i recon ,,, 76.6 lts must have been on fumes Shocked
What to guess the miles covered ??
Towing a BJ race shuttle, total weight 2350kg,, half load in the rear with a dozen wheel/tyres on the rack , motorway all the way to Dover, then 86 miles M/way.a-roads
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #15465 14th Sep 2009 8:45pm
Bluewagon
Australia 2009 Defender 110 Puma 2.4 SW Cairns Blue
I used to have a petrol County 110 with a sill tank and a manual switch that I drained dry each time before switching to the main. I could never fit more than 56 litres in until I found a partuicular fuel station with "cheap " discount fuel. Managed to get 58 ltres in both times I went there. After that I didn't go back because I had a strong suspicion that their pump was inaccurate(most likely deliberately). It also made me wonder how common fiddling with the pump measuring system was in fuel stations. Seems an easy way to make money with very little chance of getting caught.
Any chance your fuel station had a dodgy pump?
Post #15469 15th Sep 2009 4:37am
TJ101
Very much doubt it,, was a largish station, and they are pretty tight on weights and measures etc in this part of the world,, but you never know,, Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #15479 15th Sep 2009 7:27am
alantd
Very unlikely. Fuel stations are heavily regulated here. I read something recently about this and the fuel flow rates are calibrated to some extraordinary level or accuracy - way more than we would ever care about. One that started out as a 2.4 TDCi 110 XS
Post #15482 15th Sep 2009 7:35am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Well so far the best (or worst) I've managed to fill up is 69.7L put in to the tank. So I suspect that the 75L is about right (thankfully) 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #15496 15th Sep 2009 12:57pm
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
The tank capacity itself may be 75l but that doesn't include the filler neck and any fuel that's already in the system which may be a couple of extra litres.
The odd thing is, shouldn't the vehicle have gone into limp mode when it was down to 5l? I think that's what the manual says should happen. There's a whole section explaining how the engine shuts down when fuel is very low to prevent damage from running dry. 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #15524 15th Sep 2009 11:30pm
Eduardo
Some days ago we filled the tank with 65 liters just few minutes after the fuel alarm start.
I thought that the diesel thermal expansion coeficient can explain certain differences between the measures but really as I see in the literature 0.00046/°F that is not quite much and can explain a little bit more than 1 lt of difference between 5°C to 30°C.
Cheers Eduardo
Post #15550 16th Sep 2009 2:37pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
In Greece we have bigger tanks Rolling with laughter www.newfoundland.gr
Post #912530 15th Jul 2021 4:13pm
