Home > Puma (Tdci) > Puma 2.2 Air Con Kit - Performance issues |
dimhar Member Since: 07 Sep 2020 Location: Athens Posts: 5 |
Hi to everyone, also new here and my first post.
I had just installed and aircon kit on my 2012 2.2 90. Initially, it works quite well, but after running on a very hot day here in Athens Greece, seems like the air is not cooling anymore, maybe after 20-30 mins continuous running. This is observed only on the very hot days >32-35 C onwards. Even when running on the highway does not seem to do any difference. I usualy close the aircon for about 2-3 mins and then restart it and it goes good again for another 20-30 mins. I suspect due to the hotter climate here it should be the cooling fan maybe? Do I need a bigger fan? is there anyone you suggest? or any other idea? Thanks Dimitri |
5th Jul 2021 12:11pm |
Hendrix Member Since: 04 Oct 2016 Location: North Notts Posts: 103 |
The original air con can suffer from freezing up, mine does and switching off for a few minutes cures it. However mine normally takes longer than that to freeze up. Andy
1996 300TDI 110 SW 2013 TDCI 110 Utility |
9th Jul 2021 8:37am |
Hi Andy thanks for your message. Do you recon it needs a double fan on the radiator? It usualy freezes quicker when running on the highway for some reason and less when in town. I dont understand why this is happening. Do you think a kenlow fan would make a difference? the one that came with the kit seems pretty small.
Thanks |
9th Jul 2021 8:43am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2301 |
Which kit did you fit? Sounds like the condenser or the fan is too small > 110 XS Double Cab
9th Jul 2021 8:56am |
I got it from supertweaks. The fan looks like it covers not more than 50% of the grill
9th Jul 2021 9:03am |
Thank you very much. I will definitely check it out.
9th Jul 2021 9:24am |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 323 |
In the original air conditioning there is a sensor on the evaporator which is supposed to disengage the compressor if the evaporator starts to freeze. This is known to fail and lead to the above symptoms. Its a pig to replace as the whole heater unit needs to come out. |
9th Jul 2021 8:20pm |
Thank you for your recommendation although I think it is very rare for a new air-con unit to have a faulty sensor. It is strange that when I run in town under city speeds the aircon does not freeze up that much as opposed to when on the highway at high speeds. Does this make any sense to anyone?
14th Jul 2021 11:52am |
