![]() | Home > Technical > What is this unknown component in my battery box ? |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
wheel chock
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 949 ![]() ![]() |
It's a wheel chock
Nostromo Member Since: 17 Jul 2015 Location: The Mendip Hills Posts: 73 ![]() ![]() |
Many thanks,
I would never have guessed that in a hundred years !!! ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5821 ![]() ![]() |
Needed as Defenders have transmission park brake rather than wheel.
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2657 ![]() ![]() ![]() |
So it’s not an IPad stand for when you are waiting for the AA to arrive………
![]() Personally I use a block of wood, unfortunately as the original is shaped like a boomerang you can’t even throw it away because it keeps coming back…… ![]() |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1044 ![]() ![]() ![]() |
I've used it as an emergency knife - needed to cut a pie!
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3579 ![]() ![]() ![]() |
Had the same question when I bought mine.
As far as I could see, there was nothing in the owners book to explain what it was - although I am willing to be corrected! It seems to be more suitable in construction as an iPad holder than a wheel chock! |
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1297 ![]() ![]() |
They've been a standard item in the tool kit since the first permanent 4WD Land Rover, the One Ten, was introduced.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6143 ![]() ![]() ![]() |
^^^ And about as useful as the spark plug spanner that my Tdi had fitted in the tool roll
Classic
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1331 ![]() ![]() ![]() |
At least yours has a wing nut to secure it.
Reminds me of when I picked up my brand new TD5 90 County from Farnell's many years ago. After the hand over process, I had only got 1/2 mile up the road and there was a horrendous rattling/vibrating noise coming from the passenger seat box area. I turned around and drove back to the dealer to express my concerns. Turned out that the wheel chock wasn't secure and was rattling against the seat box. So much for a comprehensive pdi and test drive prior to handing over the vehicle to the customer. After that, I did 70,000 miles of completely trouble free motoring with it in three years. Happy days. |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
Welcome to the world of Defenders…. Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
