Home > INEOS Grenadier > Main Grenadier discussion thread
Page 39 of 117 <123 ... 383940 ... 115116117>
22900013A
The weight figure stood out to me, that's a whole 5-600kg more than a proper 110 kerb weight. Hopefully it's a bit lower (ie below 2500kg) so as to avoid it needing a cat c1 licence as mentioned above, as that would no doubt impact sales. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #908503 19th Jun 2021 4:45am
Grenadier
Given we all agree that this is, in essence, a new version of the pre-2016 Defender, which itself comes in at a little over 2000kgs, I’m not sure why we’re surprised by its weight. It’s not a monocoque body like JLR’s attempt at a new Def, but is a traditional body on frame design, but from what we can see on the videos, with better/sturdier everything. Bigger dimensions, bigger engine, bigger gearbox, likely more heavy duty transmission and running gear, better (so normally heavier) seating, trim and sound proofing, etc etc. All of that will slowly chip away and swallow up the extra 500kgs. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #908505 19th Jun 2021 6:19am
Mountain_man
Wales
To qualify as a Multi Purpose Vehicle in the UK (if taxed as N1 commercial) it needs to be under 2040 kg kerb weight to be allowed to have the same speed limits as a car. Otherwise it will be limited to 50 on A roads, 60 on dual carrageways ad only allowed to do 70 while on a motorway. Not a big deal as it is the same for most white vans and none of them seem to take any notice!!
Post #908506 19th Jun 2021 6:22am
^^^ The definition is "Dual Purpose Vehicle" (not multi) and for that it is the unladen weight that matters,not the kerb weight. The ULW will always be a little less than the KW.
If it is N1 and not a DPV it will be subject to the lower speed limits. If it is M1 the speed limits be as for a car but the VED will be massively greater than N1.
Let's hope the designers can put it on a diet and trim half a tonne of the ULW.
Post #908532 19th Jun 2021 12:10pm
Bluest wrote:
The weight is puzzlingly high for a non-electrified vehicle. They are saying up to 1000kg payload, but they’ll not manage to achieve that with those kerb weights unless they are expecting us to get a HGV licenses. Maybe the foreign markets they are targeting are more liberal with their weight limits.
There must be a good chance that's it's either a figure the journalist misheard or even a typo?
I'm more interested in the fact that it's being reported that there is "less than three months to go before the company plans to begin accepting deposits" albeit it does say that in relation to "ahead of an official start to Australian sales next March."
It also seems odd that there's no mules for the longer wheelbase versions running around openly and being photographed?
"Two Grenadier models will be available from the outset: the five-seat station wagon driven in prototype guise here, and a two-seat commercial vehicle, both based on a standard 2921mm wheelbase. Shortly afterwards, Ineos will launch dual-cab pick-up and seven-seat station wagon models, both using a longer 3175mm wheelbase."
Post #908533 19th Jun 2021 12:13pm
Mountain_man
Wales
Correct. I was just summarizing without the legislation in front of me. Just to further complicate it the figure on the V5 is a different measure to both KW and ulw Smile
Post #908534 19th Jun 2021 12:30pm
Bluest
To my mind the whole taxation and vehicle categorisation system in the UK needs an overhaul. Now would be an opportune time with imminent banning of ice car sales. 2007 110 TDCi Station Wagon XS
Post #908535 19th Jun 2021 12:34pm
DSC-off
Perhaps Ineos had a different vehicle in mind for their benchmarking and weight targets.
Mercedes Benz G-Class (W463)
Dimensions
Wheelbase
2,890 mm (113.8 in)
Length
4,725 mm (186.0 in)
Width
1,931 mm (76.0 in)
Height
1,969 mm (77.5 in)
Curb weight
2,354–2,485 kg (5,190–5,478 lb)
* or as the men from Steyr might say, "Here's one we made earlier....." Whistle
Post #908538 19th Jun 2021 12:59pm
County V8
Hi All
Looking at the latest images from the Schoeckl what's the large rectangular box structure between the driver and passenger seems to be branded?
Any ideas
Post #908816 21st Jun 2021 6:14pm
spudfan
Ireland
Could be part of the testing paraphanalia? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #908817 21st Jun 2021 6:25pm
County V8
It's branded .
Post #908818 21st Jun 2021 6:31pm
DSC-off
It looks to be part of the dashboard. Raised up to house an oversized i-pad type screen that is the norm these days?
Post #908840 21st Jun 2021 7:47pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
County V8 wrote:
It's branded .
Given it's getting lots of media attention, I would not put too much into that. Rgds.
Chris
Post #908847 21st Jun 2021 8:21pm
It looks to be an odd place for branding on the vehicle itself ~ you'd have to be knocking a pedestrian off their legs and onto your bonnet for them to see it clearly. So my surmise would be that whatever it is, it's detachable; and the branding works whilst it's away from the vehicle?
Post #908874 22nd Jun 2021 5:04am
County V8
Could it be a cover to stop prying eyes/lenses?
Post #908881 22nd Jun 2021 6:52am
