![]() | Home > My Defender > Tonga green TD5 |
Jon TD5 Member Since: 14 Oct 2020 Location: Uk Posts: 6 ![]() ![]() |
Good work!
Greeny Member Since: 20 Mar 2018 Location: Buckinghamshire Posts: 272 ![]() ![]() |
Just completed a bit of an engine bay overhaul, I say a bit, I could carry on for ages
![]() What I have done though is installed a 4inch intake system to the airbox from the wing outlet. Stainless steel wing outlet whihc is really nice and the overall system should help with airflow a lot. Also changed some of the pipes for silicon ones and put a bit of blue in there. Air box got paint also, the rust was very annoying. Stainless jubilee clips wherever possible. Constantly changing things though, not sure I like the way the 4inch air pipe fits so will see if I can change that to make it better. Also fitted up a galv slam panel as the old one was constantly rusting. VNT to be fitted very soon ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Instagram - @Land_Rover_Defender Last edited by Greeny on 4th May 2021 11:13pm. Edited 1 time in total |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 906 ![]() ![]() ![]() |
Tidy install, Greeny! Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 400 ![]() ![]() |
Looks a good install there greeny, looks a bit neater than mine.
I’ve never been a massive fan of how the 4” routes over the top but it definitely helps with the VGT |
Cheers Baron!
Agreed Jimbo! Isn't meant to be there is it really, a task making it fit. There is a plastic air intake which I have seen, might look a bit better than the silicon one where it bunches up. Either way it will help a lot with the airflow. Instagram - @Land_Rover_Defender |
Also painted the exhaust manifold and turbo for completeness.
Happy with the manifold. ![]() Click image to enlarge Instagram - @Land_Rover_Defender |
I used a single hose all the way to the intake and 3D printed an opening for the wing ![]() Click image to enlarge |
Yeah that is what I am thinking Jimbo that looks good, I was trying to be clever and put the 90 degree bend in around the wing support. Instagram - @Land_Rover_Defender
The only other thing I considered was to redesign the wing support so that the intake can go between the brake servo and he wing support as that would be a much neater and also shorter hose run
polsonm87 Member Since: 22 Oct 2019 Location: Highlands Posts: 8 ![]() ![]() |
looks great!
I have power!
CR turbos VNT fitted last week and mapped by Jose. Nothing crazy with the map, I didn't want to push things too much. But it is making some good power now with virtually 0 smoke which is great, no limiters either. New stainless steel intake from the box to turbo also. Here are some photos: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge New oil feed line. ![]() Click image to enlarge Stainless intake, polished this up which came out well. ![]() Click image to enlarge Current state of the engine bay: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Instagram - @Land_Rover_Defender |
Very smart Greeny!
![]() 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
Looking good!
Where’s the stainless intake pipe from? |
Stainless intake is from Ebay, a guy called Will McGregor Engineering on Instagram also. Can't fault it and looks good once polished up. Instagram - @Land_Rover_Defender
