Home > My Defender > Tonga green TD5 |
Jon TD5 Member Since: 14 Oct 2020 Location: Uk Posts: 6 |
Good work!
7th Dec 2020 4:27pm |
Greeny Member Since: 20 Mar 2018 Location: Buckinghamshire Posts: 272 |
Just completed a bit of an engine bay overhaul, I say a bit, I could carry on for ages
What I have done though is installed a 4inch intake system to the airbox from the wing outlet. Stainless steel wing outlet whihc is really nice and the overall system should help with airflow a lot. Also changed some of the pipes for silicon ones and put a bit of blue in there. Air box got paint also, the rust was very annoying. Stainless jubilee clips wherever possible. Constantly changing things though, not sure I like the way the 4inch air pipe fits so will see if I can change that to make it better. Also fitted up a galv slam panel as the old one was constantly rusting. VNT to be fitted very soon Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Instagram - @Land_Rover_Defender Last edited by Greeny on 4th May 2021 11:13pm. Edited 1 time in total |
4th May 2021 8:34pm |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 895 |
Tidy install, Greeny! Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
4th May 2021 8:40pm |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 398 |
Looks a good install there greeny, looks a bit neater than mine.
I’ve never been a massive fan of how the 4” routes over the top but it definitely helps with the VGT |
4th May 2021 8:56pm |
Cheers Baron!
Agreed Jimbo! Isn't meant to be there is it really, a task making it fit. There is a plastic air intake which I have seen, might look a bit better than the silicon one where it bunches up. Either way it will help a lot with the airflow. Instagram - @Land_Rover_Defender |
4th May 2021 9:20pm |
Also painted the exhaust manifold and turbo for completeness.
Happy with the manifold. Click image to enlarge Instagram - @Land_Rover_Defender |
4th May 2021 11:12pm |
I used a single hose all the way to the intake and 3D printed an opening for the wing Click image to enlarge |
5th May 2021 7:14am |
Yeah that is what I am thinking Jimbo that looks good, I was trying to be clever and put the 90 degree bend in around the wing support. Instagram - @Land_Rover_Defender
5th May 2021 8:47am |
The only other thing I considered was to redesign the wing support so that the intake can go between the brake servo and he wing support as that would be a much neater and also shorter hose run
5th May 2021 12:36pm |
polsonm87 Member Since: 22 Oct 2019 Location: Highlands Posts: 8 |
looks great!
18th May 2021 7:41pm |
I have power!
CR turbos VNT fitted last week and mapped by Jose. Nothing crazy with the map, I didn't want to push things too much. But it is making some good power now with virtually 0 smoke which is great, no limiters either. New stainless steel intake from the box to turbo also. Here are some photos: Click image to enlarge Click image to enlarge Click image to enlarge New oil feed line. Click image to enlarge Stainless intake, polished this up which came out well. Click image to enlarge Current state of the engine bay: Click image to enlarge Click image to enlarge Click image to enlarge Instagram - @Land_Rover_Defender |
7th Jun 2021 11:15am |
Very smart Greeny! Charlie
7th Jun 2021 11:28am |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Looking good!
Where’s the stainless intake pipe from? |
7th Jun 2021 4:27pm |
Stainless intake is from Ebay, a guy called Will McGregor Engineering on Instagram also. Can't fault it and looks good once polished up. Instagram - @Land_Rover_Defender
7th Jun 2021 4:38pm |
